6.0 problems plz help!!
Old Mar 1, 2015 | 03:09 AM
nicsal90's Avatar
nicsal90
Hello,
I have an '06 f250 which I am having engine problems at 82000 miles. The first problem is I have the banks 6 gun tuner on it and the tuner is showing a code 3,4 cannot connect to obd 2, so it's unable to read speed, oil temp, engine temp, boost, egt, or perform any diagnostics. Second the truck started leaking oil 4 days ago and today it started shutting off when u start it only once after a few minutes of being on. A little bit later in the day I drove it down the street and it does not accelerate, it just bogs out. There is no check engine light. I have an idea it's the tuner causing this problem but I am not sure. Need help please.
Old Mar 1, 2015 | 06:21 AM
mustang_309's Avatar
mustang_309
Originally Posted by nicsal90
Hello,
Have you checked the fuses? I think it is F-22 and also have you checked the oil level?
Old Mar 1, 2015 | 09:12 AM
BLADE35's Avatar
BLADE35
Welcome to fte
Remove your tunner
Check things Brett mentioned a sap and find oil leak sounds like hpo problem or base oil problem
txropinguy
Apr 25, 2025 04:11 PM
elee3
Jul 5, 2021 07:04 PM
uinta
Mar 4, 2016 10:47 PM
qdrider01
Dec 21, 2009 03:10 PM
mlongue1
1997 - 2003 F150
Nov 1, 2007 10:20 PM
