1996 7.3 help
Old Feb 28, 2015 | 09:29 PM
chriswando's Avatar
chriswando
1996 7.3 help
So I bought the truck in January, never have owned a diesel before, and of course the truck came with a ts 6 position chip. So i plugged the chip in...while the truck was running. My buddy with a professional code scanner computer and Plugged it up to my code reading port and the computer doesnt show anything. But when i go To start the truck it will run the starter and cycle, but wont fire. I think.this.is due.to.no wait to start light, i need some help guys
Old Feb 28, 2015 | 09:34 PM
JWC 3's Avatar
JWC 3
No cel ? no wait to start ? Check fuses and unplug the fuel bowl heater . Replace the blown fuse . That may be your only problem , shorted fuel bowl heater .
Old Mar 1, 2015 | 06:13 AM
91 Dually's Avatar
91 Dually
INSTALLATION:
Wait.. you say you plugged the chip in with the engine running??
I copied the following directly from the TS installation instructions.....
"Disconnect both of the negative battery terminals before starting any of the installation. Failure to do so can result in damage of the vehicles PCM (computer)"
Old Mar 1, 2015 | 06:15 AM
427 fordman's Avatar
427 fordman
Originally Posted by 91 Dually
INSTALLATION:
^^What he said^^ At the least the keys need to be out of the ignition.
Sounds like you fried your pcm.
Old Mar 1, 2015 | 07:39 AM
fordman67's Avatar
fordman67
Were the terminals in the pcm cleaned properly also? That's the wrong way all around to have done that..
99F350bigorange
13
Dec 6, 2013 12:15 PM
coreymck
Nov 15, 2012 12:44 PM
jsmitty80
Jul 17, 2011 06:22 PM
jleal_21
71
Dec 12, 2010 06:17 AM
powerstroke96ryan
May 12, 2008 10:33 AM
