6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
cabin air flow switch not working
Old Feb 28, 2015 | 02:39 PM
countryboy73703's Avatar
countryboy73703
hey,
So my air flow is acting weird. A/C and Heat both work correctly, all vents work as should, my issue is that 1-3 air flow settings do not work, 4 (high) works as it should though. If I'm idle 1-3 doesn't work, if I leave it one 1,2 or 3 then it will blow only if I'm cruising down the road, but it wont change with the change of the air flow switch. 4 (high) work in idle or while moving. I'm not sure if it's the blower or the switch, I am going to try cleaning the switch, but it's rainy and chili out today. so It will have to wait.
any help is appreciated, also proper terminalogy for the switch would be great so I can look he part up. thanks
2008 F250 6.4. with manual climate control (not digital auto climate control)
Old Mar 1, 2015 | 01:31 PM
countryboy73703
Bump.. Any advice?
chargerrich
Nov 4, 2017 09:36 AM
unclejosh
1997 - 2003 F150
Jul 26, 2010 11:40 PM
Zmanzuniga
Jul 18, 2010 12:22 PM
Fusion
Mar 30, 2003 02:45 PM
CantDrive55
Jan 6, 2002 09:34 PM
