temp wire no voltage
Old Feb 28, 2015 | 02:15 PM
brian.b's Avatar
brian.b
Hey guys I have an 86 f 150 with a straight six I'm trying to get the temp gauge to work but there's now power on the wire has anyone had this problem and no what it could be...thanks a lot for any help.....
Old Feb 28, 2015 | 02:38 PM
86fn150's Avatar
86fn150
the temp wire to the sender? sender grounds out .no voltage
Old Feb 28, 2015 | 03:34 PM
82F100SWB's Avatar
82F100SWB
If you ground the wire that plugs on the sender, the guage should peg.
Old Feb 28, 2015 | 05:07 PM
brian.b's Avatar
brian.b
I thought that would be like the fuel gauge and have 5 volts .........so it's just a ground........Is it a blue wire or green......not really sure on the color.....thanks guys...
Old Feb 28, 2015 | 07:09 PM
JimsRebel's Avatar
JimsRebel
It should have 5-6 volts on the wire that connects to the sender if it is hanging loose.
Jim
Old Feb 28, 2015 | 07:14 PM
ctubutis's Avatar
ctubutis
It is either red/white-stripe or white/red-stripe and operates the same as the oil pressure.
There is a separate sensor on the radiator hose neck that has two wires, this sensor is used exclusively by the computer and has nothing to do with the dash gauge.
Brnfree
Dec 1, 2013 04:46 PM
fdude64
Mar 19, 2011 02:05 PM
Beater86
Jun 26, 2006 05:45 PM
Chumbucket
Electrical Systems/Wiring
Apr 21, 2006 05:52 PM
jevanof
20
Jan 13, 2003 08:11 AM
