temp guage help
Old Mar 17, 2011 | 05:36 AM
fdude64's Avatar
fdude64
temp guage help
i am going to put in a mechanical temp guage. there are two sending units on my intake 95 f350 4x4 460. which one do i use? they are both behind the dist. one on each side of it. one has one wire to it the other has 3 i think
Old Mar 18, 2011 | 05:46 PM
Bear 45/70's Avatar
Bear 45/70
The one wire one is for the temp gauge, the other is for the EFI. To confirm this, pull the wire off the sender, ground the wire (not the sender) and turn the ignition key on. If temp gauge pegs out, that is the one to use.
Old Mar 19, 2011 | 02:05 PM
fdude64's Avatar
fdude64
yup it was the single wire one
