Long time before reverse engages
Old Mar 10, 2015 | 03:45 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
Originally Posted by Mark Kovalsky
Two seconds is the normal engagement time for a 4R100. If that's what you have it's normal. If you have a 5R110 it is too long.
I'll second that, my 4R takes a second to engage reverse if shifted straight in from Park, shifting from Drive is the same. Makes rocking out of a hole a real pain in the butt off-road. I'll be fixing that on the trans rebuild.
No input on the initial issue and the four second delay when engaged straight from Park, that's odd. I'm wondering if the reverse clutch and steels are a bit worn, thus increasing the tolerance resulting in the longer delay?
Old Mar 10, 2015 | 08:19 PM
Unklebob's Avatar
Unklebob
if the clutches were worn, would it only do it on the first shift from park after sitting for an hour or more? Then go away completely for the rest of the time driving?
once that first delayed reverse shift is done, shifting into reverse is immediate and firm for the rest of the trip..
Old Mar 10, 2015 | 08:39 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes it would. My guess is that the seals in the reverse clutch are worn.
Old Apr 1, 2015 | 08:28 AM
Unklebob's Avatar
Unklebob
Just thought I'd provide an update. Been a few weeks since I added the Lucas to the fluid. No issues since. Don't know if I was actually a little low on fluid, or if the additives helped. But reverse is just fine now. Maybe a one second delay in shifting to reverse before it engages. thanks.
Old Apr 1, 2015 | 08:43 AM
harley4jcs's Avatar
harley4jcs
NOT BAD for $24
Old Apr 1, 2015 | 09:18 AM
Unklebob's Avatar
Unklebob
Certainly better than the $2500 I was about to pony up for a new tranny.
Old Apr 2, 2015 | 11:49 AM
74Mav's Avatar
74Mav
Well, this is very timely... I was thinking mine might be acting up as well, since I was so used to my '05 F250 and how quickly it engaged in forward and reverse. I timed my cold and warm times today for my '01 Ex, and I'm happy to say they are less than 2 seconds. Thanks for making a newish Excursion owner happy!
KAT_Ayanami
Mar 8, 2022 06:04 PM
mmenzies
Mar 4, 2013 11:23 AM
chrison600
Oct 13, 2012 12:56 PM
jsutton
Apr 4, 2008 09:37 AM
afinepoint
Oct 30, 2004 09:39 AM
