Air in fuel line Video (Pre-Hutch Mod)
on
I made this video some time ago but just got it posted.
When using the fuel pump to empty the tank, it was surprising how much air was introduced into the fuel line AFTER the pump started running
The fuel level was between 1/2 and 1/4. I planned to do the mod earlier in the week, but then didn't have enough fuel to get around and had to put some fuel in her, LOL.
I hope this works
Thought this might help someone
I hope this works
on
Feedback on the video?
Hey, if you watch the video, let me know if it plays okay, annotations show up (not on mobile it says?), etc.
My first Youtube video upload
Oh- and if you have a favorite, low cost video editing suite, I'm looking for suggestions for this and other personal uses. Zoom, rotate (cell phone camera), trim, combine, mix, slideshow (video from pics, with soundtrack)...etc
Thanks!
Thanks!
on
I don't know about any effect on a gauge
I know I had a visual image of hitting an injector with a ball peen hammer when I saw that gulp of air
I was careful to quickly cycle the key to not allow diesel to empty the clear tubing before pumping again. That is what concerned me the most- the gulp of air AFTER the pump was running
It was repeatable and happened every time. Hence the video
IMHO, this suggests the problem with the fuel supply side to the pump is even more troublesome than just losing some fuel capacity when low- and it can't be avoided by simply filling before 1/8 tank.
I figured it was my chance to give back to the community
on
Yeah, I'll try to do a bit better next time. 15s isn't much to work with, LOL.
You can absolutely see air with a FP gauge. Do a WOT test. If the FP gauge drops below 55 PSI (maybe a little higher on stock sticks), air in fuel steps forward from the usual suspects.
In your opinion, the gulp of air I had...would it show up as a needle bounce, stay low, or what? (Yes, I did resolve this issue already, but diagnostic info is always helpful to all )
Also curious so I know what to watch for on my digital fuel pressure gauge? (ie- 3 secs low pressure, sudden drop of 10psi, etc
on
I knew I was likely getting air when the fuel level got low, but I never expected to be getting air every time the pump cycled!
I read a good explanation of it on FTE, but a few bubbles here and there didn't seem like such a big deal...until I saw the gulp. Hmmm....no wonder we have starting issues- start the fuel pump, send air to the injectors...duh! LOL.
Rich- Thanks for the good info again. Watching the fuel pressure drop after starting doesn't necessarily mean the fuel pump isn't able to keep up, it could just be air. Good to know!
