What would y'all do?
Old Jul 23, 2003 | 02:43 PM
AUBronco40's Avatar
AUBronco40
Question What would y'all do?
Ok I just put on a bassani y-pipe and I love it...it sounds great but its to loud in the cab. Mainly because I have it just dumping out through a turn-down right after the cat. And I am planning on getting the HTC heades from bassani as well.
My question is: before I get the headers I want to finish out the exhaust back to stock location. So I am trying to determine which muffler set up would give me the sound I am looking for and no annoying drone in the cab around 2000+ RPM. The sound I want is pretty much the sound that is there now....low deep gurgle like noise (you know wob.wob.wob). But I don't want any craking and poping after I get off the accelerator that I hear with so many trucks. And I want it to be 3" all the way out prorbably with no tip.
I was thinking about gibson but I heard one of thier sound clips for a 4.6(I know its not the 5.0 like I have) and it didn't sound very good. So I was thinkng maybe flowmaster 50 series SUV/truck or an edlebrock set up. What do you guys think. Are there any other out there that would give me this sound?
Old Jul 23, 2003 | 03:11 PM
agelder's Avatar
agelder
Not exactly the same vehicle, but my brother in law has dual flowmaster 40s on his modded Crown Squire Wagon 5.0 (of all things) and it sounds really good. He has headers, a towing cam, and an h-pipe. Sounds wicked when he gets on it, but quite bearable int he cabin (even w/sound proofing removed) around town.
Old Jul 23, 2003 | 03:15 PM
phantom22's Avatar
phantom22
If I had your engine, id go with a Borla. They sound sweet at an rpm, and dont have thatpopping after acceleration like my flowmaster does. I just got a flowmaster to save big money on gas.
Old Jul 23, 2003 | 09:43 PM
agelder's Avatar
agelder
I think flowmasters sound pretty good on v-8s, and you may have a problem with the 3" pipe causing the popping rather than the muffler. It may be too much for the 3.0 (not enough backpressure?). I'm thinking about either a 2.25 or 2.5 on my aero 3L.
Old Jul 24, 2003 | 06:24 PM
Hit Man X's Avatar
Hit Man X
Glasspacks sound like total crap, nasty popping, and lose power due to small diameter. They are cheaply made and wear out fast. I despise the WOT sound of them.
Flowmasters sound good but DRONE bad on the freeway and power gains are very limited with them. Basically a "hey look I am loud and slow!" I don't see any major power gains with them...most don't either as the chambers limit flow!
Actual power comes from straight through design mufflers. The larger case keeps the sound down and keeps as well as increases the lowend torque of the exhuast. Magnaflow is awesome, Dynomax, Borla, Corsa, B&B are all on the same page. These make power and keep the sound at a normal level (very limited droning and no nasty sound either)...I don't consider a 40 Series Flowmaster normal, liveable, or okay for the daily freeway commute. Is a 10-14db increase in sound okay? Not to me. Why be uncomfortable when driving?
I have a 5x11x22 Magnaflow on my F-150 and the sound is great...very deep and mellow. Nice at WOT. I have Hooker LTs and a 2.5"->3" exhuast with a Carsound cat. The Drone is very, very unobtrusive...nothing like a Flowmaster.
To give you an idea what I think about Flowmaster...I went from a 50 Series Flowmaster to that Magnaflow on the F-150. I went from a 40 Series Delta Flow (came with it!) to a Magnaflow on my Z71. That's got to tell ya somethin...
If you need a sound increase, slap on a high flow cat ($75 typically from mail order places) and some headers to increase flow, sound, and power. Then it is okay to be mildly loud. I'd rather be fast and sneaky than loud and slow.
Suprisingly I may sound like an old man but being in my early 20's, I now have a more refined sound taste for vehicles. I enjoy the smooth, exotic sounds vs the old loudass trash sound. Most of the ones I describes are very mellow putting around and let out a monster WOT sound when the hammer is dropped. That is how a performance vehicle should be.
Old Jul 25, 2003 | 11:10 AM
AUBronco40's Avatar
AUBronco40
What do you think about A 5x8 oval x 18" (or 22" which one would be more quiet in the cab? or a 14" stainless one.)long case magnaflow....think that would sound good matched up with the Y-pipe w/ one high flow cat....and eventually the HTC headers. By the way i went to magnaflow's site and the sound clip for the supoercharged 4.6L harley F-150 is just about exactly the sound I am looking for.
Old Jul 25, 2003 | 11:26 AM
Hit Man X's Avatar
Hit Man X
AUBronco40...
Your exhaust setup planned is similar to mine except with shorty headers. It is nice under light acceleration and lets out a nice fairly loud tone when the pedal is down.
The 22" case is also wider...it is a VERY tight fit to get that 5x11x22 on my truck. It isn't too loud and I am unsure of what your sound tastes are. The 5x8x18 is going to fit far easier...knowing that now I probably would have gone with that due to size restraints.
The 5x8x18 is going to be slightly louder as there is less sound matting to control flow, it will still be very mellow...the sound difference is going to be hard to tell.
With either of the larger cased ones, freeway sound it very minimal. Somehow all good straight through designs are very quiet almost silent on the freeway...which is how I think a performance exhaust should be.
I hope that helps...
Old Jul 25, 2003 | 01:14 PM
AUBronco40's Avatar
AUBronco40
Hit Man X, you have helped alot actually thank you. I didn't even know magnaflow had suck good quality before now. Now just to save up some money.
Old Jul 25, 2003 | 02:40 PM
Hit Man X's Avatar
Hit Man X
Excellent glad I could be of assistance.
Old Jul 27, 2003 | 02:11 PM
AUBronco40's Avatar
AUBronco40
hey Hit Man two more questions for ya,
....did you get the center to center or offset or what? I am just want to know which one will fit best. and did you get a tip with yours? I am usually opposed to tips but thats just because most people around here get resonators, and I hate those. but i saw magna flow has some just single sheet 45 degrees slash cuts that look real good.
Old Jul 27, 2003 | 02:37 PM
Hit Man X's Avatar
Hit Man X
The muffler I run is a No. 12588. Single 3" in/dual 2.5" out that is 5x11x22. If I had the redo, the No. 12288 single 3" in/dual 2.5" out will fit a bit easier as it is narrower. Both of those are Center inlets with dual outs. Are you planning to run single tailpipe or two tailpipes?
I hate tips! Espically 3.5"-4" tips with 2" tailpipes! Hahaha. That is how my Z71 came when I picked it up used...needless to say as soon as I got home out came the WD-40 and the hacksaw. Those big tips look nasty and megaphone the sound. That truck had you typical "***** kicker/redneck" parts on it like...bug deflector, nerf bars, cheap drop in bedliner, and that 40 series Flowmaster with big tips!
The only ones I'd use would be the nonresonator tips of the same diameter of the tailpipe if you wanted the tips seen directly out back or off to the sides. They'd look less obtrusive, keep sound down, and add a bit of shine to the tailpipe.
My pipes are dropped right by the bumper... a la Lincoln Town Cars, old muscle cars, etc. Looks very classy and clean.
Lemme know if you need any more help...you can email me if you wish. Besides I would like to know what you think of this setup when you get it installed.
BTW...Bronco's are cool as hell! I really want a '94-'95 Eddie Bauer, 351W, 4R70W, dark green or black, and optioned out. I think the best part of them is that the camper comes off and that back window rolls down.
Old Jul 27, 2003 | 10:55 PM
AUBronco40's Avatar
AUBronco40
Well I am planning on running stock location out the passenger side behind the rear wheel. right now it is just dumping out through a turndown right after the cat so i can't open the back window or take off the top with out suffocating.
I think what I might do is go to a muffler shop and get them to bend up some 3" pipe out to where I want it to exit and then just get the muffle later on when I have more money. Cause I spent it all on the y-pipe (I am a broke college kid so that broke the bank).
So pretty much i don't know when its gonna get installed but i will post to let everyone know how it goes.
