electical help needed
Old Feb 26, 2015 | 09:27 PM
trevor015's Avatar
trevor015
i have a 1988 F150 with a 351w. one day my running lights quit working excluding the headlights, brake lights and turn signals still worked. listened to my dad and grand dad changed the switch and a relay also made a jumper from the headlights to the running lights so they would work and it did until i went to start it woud not start has spark and you can hear the fuel pump come on and smell it a little bit when trying to start. then the headlights are now on with the switch off and its not touchin any other wires and i unplugged the switch to see if that would help and it didnt. what did they screw up on it.
Old Feb 27, 2015 | 06:48 AM
subford's Avatar
subford
You do not have a relay for lighting so I do not know what you changed unless it was an add on for fog lights, or something that Canada requires.
Remove the wire you added and then find out why the lights do not work.
When you say running lights I am not sure what you are talking about. Do you mean marker lights or some running light in the grill that says the ignition is on?
Old Feb 27, 2015 | 06:56 AM
ncranchero's Avatar
ncranchero
Remove the jumper!
LIGHTING DIAGNOSIS FROM FSM
Symptom:
All tail lights and marker lights out-headlamps OK
Possible causes:
1.Loose wiring connections
2.Open wiring or poor ground
3.Blown Fuse (fuse #4, 15A opposite corner from flasher)
4.Damaged headlamp switch
Old Feb 27, 2015 | 07:03 AM
subford's Avatar
subford
Originally Posted by ncranchero
Remove the jumper!
Symptom:
Possible causes:
But we have no idea that he is even talking about the "tail lights and marker lights out".
Think Canada on this thread.
Old Feb 27, 2015 | 07:11 AM
ncranchero's Avatar
ncranchero
True, eh?
Nobody had replied and I see you did as I was also checking out the wiring so I'm guessing/assuming at this point also.
No DRL listed in the 'Merican manual. The headlamps are on a separate circuit, not fused but with a fusible link.
A primary failure of this tail/parking/marker light circuit is faulty add-on trailer wiring.
Old Feb 27, 2015 | 12:46 PM
trevor015's Avatar
trevor015
There were two relays behind the air cleaner and they thought one them was bad so we replaced it and with running lights yes I do mean the side marker lights instrument cluster and tail lights I clipeed the jumper wire they and now with the switch off and hooked up batter lights come on
Old Feb 27, 2015 | 12:49 PM
trevor015's Avatar
trevor015
And the fuses are all good
Old Feb 27, 2015 | 01:22 PM
subford's Avatar
subford
The two relays are the power relay and the fuel pump relay.
Neither relay has anything to do with the lighting./
Old Feb 27, 2015 | 02:55 PM
bashby's Avatar
bashby
These trucks have too small wiring for the headlights. They are known to melt tbe wiring at the plug for the headlight switch. Check there for wires melted together. After you fix the short you can install headlight relays to reduce the load on the circuit so it wont happen again.
Old Feb 27, 2015 | 03:07 PM
trevor015's Avatar
trevor015
It looks like it's brand new and no melted wires the truck had been sitting for awhile and with its age maybe the wires going to the fire could have a short I lookied inside the cap and there's no signs of a short or bad wires
Old Feb 28, 2015 | 04:32 PM
trevor015's Avatar
trevor015
Update
Lights work now but fuel pump stays on when battery is hooked up. When switch is on the front tank the pump behind fuel filter stays on and when on the rear tank the pump inside of it stays on. The fuel pressure regulator holds vaccine and still have spark just won't start is this possibly the pcm
Old Feb 28, 2015 | 05:03 PM
bashby's Avatar
bashby
A bad computer can make the fuel pump run al the time.
facets
Electrical Systems/Wiring
Feb 15, 2014 04:46 PM
J-W
Mar 6, 2011 04:52 PM
IrishChef
Oct 30, 2010 06:52 PM
whitewood
Jan 22, 2010 07:42 PM
scheer89
Nov 30, 2008 09:04 PM
