No Rear Lights
Old Oct 30, 2010 | 05:46 PM
IrishChef's Avatar
IrishChef
No Rear Lights
Hi all....
'89 F150 5.0 .....rear blinkers and stop lights work, as do flashers. No "running" lights. Would this be a headlight switch problem? I took a good look under the truck at what I thought might be the most likely places where a break would be, but all wiring seems fine. Thanks in adavance.
Old Oct 30, 2010 | 05:50 PM
littlehusky's Avatar
littlehusky
do they work if you pull it back 1 position instead of 2? I/E only your marker lights on?
Thats where i'd start testing is at that headlight switch.
Old Oct 30, 2010 | 05:56 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Do you have dashboard lights?
If not check the topmost fuse in the box. I think it's #4
Sometimes the fusebox gets hot and the connections go bad on the back side.
Old Oct 30, 2010 | 06:02 PM
IrishChef's Avatar
IrishChef
No, they don't work in the first pull-out position, and no other lights are affected. Thanks for the quick responses!
Old Oct 30, 2010 | 06:11 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Try playing with the switch between positions.
You may find a "sweet spot" that will verify it's the switch before you spend $60 on a non-returnable electrical item you didn't need.
Ask me why I know...
Old Oct 30, 2010 | 06:32 PM
IrishChef's Avatar
IrishChef
LOL...I know the feeling...yeah, I'll try it.
Old Oct 30, 2010 | 06:52 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Sometimes the plug for the switch melts as well, causing all kinds of problems.
This should be correct for your 1989 application.
Amazon.com: Pico 5311PT 1987-1993 Ford "F" Trucks Dash Headlight Switch Nine Lead Wiring Pigtail: Automotive
bobbyg36
20
Dec 27, 2017 12:52 PM
wrd0225
Sep 30, 2014 10:53 PM
Wicked Endings
13
Nov 9, 2010 06:54 PM
SparkyRnD
Sep 8, 2010 03:17 PM
