Powerstroke exhaust
Old Jul 23, 2003 | 02:17 PM
SBFD8's Avatar
SBFD8
Smile Powerstroke exhaust
Hello,, I have a 2000 CC 4x4 powerstroke the down pipe is 3in and the rest of the exhaust is 31/2in. Would it help to change the down pipe to a banks 31/2in and change the muffler to a less restrictive one?????? Or would I be better replacing the whole system to 4in??? Thanks ALL
Old Jul 23, 2003 | 02:29 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Powerstroke exhaust
If you're going to make some big power mods to the truck, the the 4" is the way to go. For at, or near stock power levels the 3.5" will be fine.
Old Jul 23, 2003 | 02:38 PM
SBFD8's Avatar
SBFD8
Thanks for the reply. I have a power chip already installed it was in when I bought the truck. Not sure what size the chip is it was made by Performance Diesel if I remember right, I tried to call the phone numbers on the chip but they are no longer in service. I guess I will go with the 4" exhaust. Thanks AL
Old Jul 23, 2003 | 03:21 PM
johnsdiesel's Avatar
johnsdiesel
Powerstroke exhaust
Even if you replace the factory downpipe with one of the same size it will be an improvement over the squashed factory tubing. If you are going to run any kind of a chip I would recommend a 4" exhaust and a pyro gauge.
Old Jul 23, 2003 | 10:54 PM
ehumaui's Avatar
ehumaui
Powerstroke exhaust
Im in the process of getting a new exhaust system, what do you guys suggest? Bullydog 4" or 5", Magnaflow 4", Banks 4", ATS 4"
Just wondering what eveybody is running?
Old Jul 24, 2003 | 07:29 PM
DCSpecial's Avatar
DCSpecial
Powerstroke exhaust
I run a B&B performance Exhaust......sounds good and looks great......here's a pic of the tip:
A buddy of mine runs the ATS Dual exhaust.......looks real nice and sounds good too.
Besides the size difference and whether or not it's stainless the things that set the different exhausts apart from each other is the finish and the sound.
Out of your choices I'd run the ATS or maybe even the Bullydog 5"....
Hope this helps.
cowmilker08
Jul 15, 2013 08:18 AM
fordbedflat
13
Jan 30, 2010 11:52 PM
sicf250
Jul 29, 2005 09:03 AM
SBFD8
Jan 12, 2004 01:31 PM
Riley_7.5
Exhaust Systems
May 10, 2000 02:04 PM
