Red Battery Light?
Old Feb 26, 2015 | 10:54 AM
DSE350's Avatar
DSE350
Red Battery Light?
My red battery light comes on at 2500 RPM's and above- I've seen the opposite on other vehicles before, where the belt was slipping at lower RPM's- Does this mean there is undue resistance in the belt path somewhere? Any idea if it is a loose belt or the alternator? It's has been very very cold here lately, but if it were the battery I would expect the light to be on at lower RPM's. Any ideas?
Old Feb 26, 2015 | 02:23 PM
EagleFreek's Avatar
EagleFreek
What year van? We had a F350 that the alternator light would come one while driving and found out the alternator was overcharging.
Old Feb 26, 2015 | 09:32 PM
Wildman25's Avatar
Wildman25
Generally the Red battery light will come on if there is a problem with the Alternator Not Charging.
The Cold weather could be having some affects with the Diodes inside the Alternator.
Do you have belts or Serpentine Belt???
Old Feb 27, 2015 | 05:26 AM
DSE350's Avatar
DSE350
2004 E350 5.4L V8
How do I check- can I measure voltage across battery terminals while someone holds the engine at 2500, or does it have be measured right on the alternator?
Thanks!
Old Feb 27, 2015 | 08:39 AM
EagleFreek's Avatar
EagleFreek
Thanks!
Right at the battery should work fine. If you can get to the back of the alternator, it will be more accurate. Some of the chain auto parts stores will test your alternator on the car for free.
Vijay
Sep 10, 2014 11:13 AM
Youngm
1997 - 2003 F150
Aug 22, 2012 04:00 PM
happycamper116
Oct 1, 2008 08:20 PM
fiatguy
Dec 4, 2004 06:38 PM
howarda
Oct 19, 2004 11:57 AM
