Sponsored by: Auxito
Battery Light
Old Aug 15, 2012 | 05:31 AM
Youngm's Avatar
Youngm
Battery Light
My battery light flickers on and off, sometimes its steady, other times it is off. I had the battery checked and it seems fine. The terminal connections are clean and tight. Does this mean my alternator is going out? I wanted to check around b4 taking it to Ford for no reason.
Old Aug 15, 2012 | 09:43 AM
dbreckman's Avatar
dbreckman
Have the alternator checked (requires removing it) but that what it sounds like. When they check it make sure they test it under a load too.
Old Aug 15, 2012 | 12:21 PM
Bluegrass 7's Avatar
Bluegrass 7
Usually the brushes are not keeping contact from wear and rough surfaces due to age.
Good luck.
Old Aug 22, 2012 | 04:00 PM
Youngm's Avatar
Youngm
Thanks for the info, I switched out the alternator and the light went away. I went ahead and installed a new serpentine belt since it already needed to be loosened to take out the old alternator. 2 birds, one stone.
Vijay
Sep 10, 2014 11:13 AM
virgil spells
General Diesel Discussion
Sep 7, 2013 12:06 PM
npccpartsman
Escape & Escape Hybrid
13
Jan 10, 2011 09:08 AM
kenneBF250V10
Aug 12, 2008 02:24 PM
njstevens
Jan 7, 2008 09:06 AM
