Tapping noise when cold?
Old Feb 25, 2015 | 10:40 PM
Macrobb's Avatar
Macrobb
What do you think? It seems to only do this when cold, and is this intermittant metallic tapping noise coming from the drivers side.
Note that this is my new engine, with only 2K miles on it.
Oh, and oil pressure is fine, cold it hits 30 PSI and levels off within 10 seconds, and that engine had been running for 30s to 1 minute already.
Ideas?
Old Feb 25, 2015 | 11:45 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
odd.id describe that more of a clicking.sounds so light and out of place,id guess it was a hoax of you tapping on the camera or something lol.
click.....click......click......click......click.. ...click,click,click,click,click......click......c lick......click.........click.....click,click,clic k,click,click.
am i hearing the right noise? in person,it most likely sounds more like a tap,than it does a click in the vid right?
Old Feb 26, 2015 | 12:01 AM
Johnny L's Avatar
Johnny L
Could it be related to a belt driven accessory?
Old Feb 27, 2015 | 09:37 PM
Macrobb's Avatar
Macrobb
Yeah, it's not consistant. To me, it sounds like a sharp tap/click, like someone beat a chunk of metal with a hammer quickly.
Could be, but what?
Alternator runs way too fast. AC isn't on at all. Could be the PS pump, but that usually makes whining noises, and it's also running way too fast.
I'm pretty sure it's engine related, due to the speed of the taps.
Old Feb 28, 2015 | 08:41 AM
MotherTruckinMarine's Avatar
MotherTruckinMarine
Check for play on the water pump. Take belt off the tensioner and see if the fan has any wiggle. Sounds like mine before the water pump went out. Sounds to me like it's something to do with an accessory. Seems to me if it were an internal engine noise there would be more resonance or a more hollow sound, if you will.
Old Feb 28, 2015 | 08:52 AM
ozdatman's Avatar
ozdatman
Did you look at all your push rods? As they turn they can make an intermittent noise if they are slightly out of spec. Like when lifters on a little motor spin. but our lifters don't turn so that's why I'm thinking push rod.
Old Feb 28, 2015 | 03:21 PM
Coutu's Avatar
Coutu
Although I can't hear it too good as my volume doesn't go up enough, mine has a tick on the drivers side too. Very faint as you can't hear it close to the truck, but from far away you can. It's got 49,000 miles on it, so I doubt it's internal.
I'll be interested to see what it is, and like stated above, an accessory is probably what's causing it.
nomad_archer
Feb 11, 2019 10:27 PM
tmwag
Escape & Escape Hybrid
Jan 10, 2013 11:20 AM
97ranger xlt
1983 - 2012 Ranger & B-Series
15
Oct 6, 2008 08:18 PM
meh129
3.8 & 4.2L V6
44
Aug 10, 2005 05:52 PM
cmoore99
Feb 17, 2004 08:49 PM
