Ok need some help, replaced HPFP 38,000 miles ago. Truck began going in limp mode without engine light, wrench came on in dash, gave codes for brake switch, anti-theft, some other weird codes. Had those codes cleared, ran for while then water separator came on, drained the water out, came back on. Read some forums, so I removed and cleaned the housing, cleaned off the sensor. Had code cleared and ran good for about a week. Then guess what engine light comes on, limp mode. Went to Auto Zone, pulled code P0088. This truck runs awesome until limp mode. No other problems. I take it to the ford dealer, scanner pulled P0088 and the water separator code again. I have read alot of remarks about this P0088 code. Can there be another cause for pulling this code, only 38,000 miles later. I had them do the TSB 12-07-07 but I have also read it can only be done if the P0088 is the only code. Please advise, my bill is up to $4500.00. I just really feel there is an underlying issue with these 6.4's. Thanks for any advise!!!
You have to drain the water separator monthly, run a good fuel lubricant, and there is a reflash for the P0088 that might fix your problem.
[QUOTE=bubbasz1;15120580]You have to drain the water separator monthly, run a good fuel lubricant, and there is a reflash for the P0088 that might fix your problem.[/QUOTE
OK they did the reflash but it was showing both codes, the P0088 and then the one for the water separator. Would the reflash not work then?]
Thanks for reply, I will replace water separator sensor, but remember this HPFP was just replaced 38,000 miles ago. Do you still think it needs to be replaced again?? I was hoping that everything I have read about this faulty P0088 code that it might be something else throwing the code, like EGR being replaced.
P0088 X X Fuel Rail/System
Pressure - Too High
This error will be set if the fuel pressure in the rail is too
high and the controller cannot regulate it to the setpoint.
20 % “overposition” of
the PCV [% PWM]
3% deviation of the fuel rail pressure
to the fuel rail pressure setpoint
Low pressure system, wiring to
VCV and PCV, FUP sensor, pump
