EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
CAC drain?
Old Feb 24, 2015 | 09:27 AM
clydesride's Avatar
clydesride
CAC drain?
Ok so not knowing all that much about the techie side of this engine I find myself wondering if having a drain off for the CAC would be an idea??
I know it is incredibly manual method of me to think of but if the CAC got drained off now and then would it help to reduce the intake of water to the engine when I romp on it now and then?
Just putting it out there to the guru's...
Old Feb 24, 2015 | 09:52 AM
seventyseven250's Avatar
seventyseven250
Is water pooling in there and building up over time? I'm not an expert on these type of systems, but that doesn't sound like the sort of thing that would be common.
Old Feb 24, 2015 | 05:15 PM
clydesride's Avatar
clydesride
I'm not sure if it builds up or not...sometimes it stumbles a bit if i crank it and I wondered if it was lingering water or something developed that day?
Old Feb 25, 2015 | 09:31 AM
jwhitetail's Avatar
jwhitetail
Sounds like water, no it won't hurt to put a drain, there's video out there of guys doing it. One guy does trail runs with a 1/8 hole drilled and running it WOT and than plugging it and there only 1psi difference in boost.
Old Feb 25, 2015 | 05:22 PM
clydesride's Avatar
clydesride
I will look into it then and may end up installing a drain of sorts...figured it may save me a cat or worse?
jmcquarry
6.7L Power Stroke Diesel
25
Jan 18, 2012 07:13 PM
RickBraden
Nov 28, 2011 04:03 PM
KC8QVO
6.4L Power Stroke Diesel
May 18, 2011 10:06 PM
