Draining Water
Old Jan 16, 2012 | 10:29 PM
jmcquarry's Avatar
jmcquarry
Draining Water
Has anyone ever observed a noticeable amount of water when draining from the separater valve? I try to do it each time I refuel, however all I ever see is pure diesel. I refuel from various stations and I doubt the quality is always the best. I have had two SD's 2010 and 2011 and never found water, is it possible it is there and not separated enough where it is not visually apparent? Almost seems to be a waste of fuel, but rather be safe than sorry..........
Old Jan 16, 2012 | 10:44 PM
GCLL's Avatar
GCLL
I drain into a mason jar. There is maybe one eye dropper sized drip of water at most in the jar.
Old Jan 16, 2012 | 10:48 PM
Chad149's Avatar
Chad149
I used to do it that way but never saw anything. Now days I just drain it when I change my oil (which I do on a 3k interval).
Old Jan 17, 2012 | 12:23 AM
kper05's Avatar
kper05
No water so far with 26,200 miles.
I drain monthly per the manual, sometimes more if I'm under there checking other things.
Old Jan 17, 2012 | 12:48 AM
'08FX4's Avatar
'08FX4
I have only drained it a couple times, haven't seen any yet- in my '08 I used to be able to see some. But not a real lot. Maybe a shot glass full every 5 tanks. Starting to think it isn't catching any....?
Old Jan 17, 2012 | 07:27 AM
djousma's Avatar
djousma
Holy crap. thats a lot of water. I have never seen any water.
Old Jan 17, 2012 | 07:53 AM
TxFordGuy1's Avatar
TxFordGuy1
I've never seen any in the 5 months Ive been checking it.
Old Jan 17, 2012 | 07:57 AM
'08FX4's Avatar
'08FX4
That was my old truck, I haven't seen a drop in the 2011....
Old Jan 17, 2012 | 09:17 AM
EpicCowlick's Avatar
EpicCowlick
I've been more attentive to the water separator and have been careful to test overnight. I have yet to see ANY water, even a micro bubble whatsoever in any sample I have taken. Just for fun, I added water to a sample I drew out of the DFCM just to see what it looks like. Sure enough, a nice bubble of water on the bottom of the container. It would be very hard to miss if any water existed.
Old Jan 17, 2012 | 09:25 AM
'08FX4's Avatar
'08FX4
With the amount of fuel we are all burning, does anyone believe that there is zero water in any of the fuel we are using from different stations, suppliers all over the country? I don't. The only explanations I can come up with are (1) the water separator ain't working, or (2) the fuel pick up in the tank is such that the water is staying in our tanks, and not making it into the water separator to begin with. Any other ideas?
Old Jan 17, 2012 | 09:31 AM
EpicCowlick
I have read of at least two instances where water was found in the separator. A small amount and not enough to set of a warning but visible water nonetheless. Maybe it's a good time to start a conspiracy theory here. Is it common practice for refineries to add emulsifiers and therefore shoot a bunch of unseparatable water through our fuel systems? Any takers?
Old Jan 17, 2012 | 09:45 AM
my996duc1's Avatar
my996duc1
I might know of one person who might jump on this and continue with a Ford sucks and they are out to get you and we are all driving a ticking time bomb.... but he is over at RV.net serving up the Dodge and Chevy boys big portions of Ford Sucks koolaid right now.
________________________________
I've never found water when draining on mine.
I only have around 21,000 miles but it has been driven across country twice so I am getting a mixture of fuel from different areas.
_
Old Jan 17, 2012 | 11:08 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Any other ideas?
Adding an demulsifier, an emulsifier or a water solubilizer.
I'm not picking a side in the E vs. D debate. I've read articles on other diesel forums that Power Services says Diesel Kleen (grey bottle) and Diesel Fuel Supplement (white bottle) have no emulsifiers or demulsifiers, and that Diesel 911 (red bottle) has an actual solubilizer to counteract filter icing. That's what I use, I don't know what other brands have.
Old Jan 17, 2012 | 11:47 AM
6.7Fan's Avatar
6.7Fan
The WIF warning works on my truck....it came on 3-4 weeks ago. It was actually the first time I'd drained the separator. Unfortunately, I drained it into a dirty 5 gallon bucket, so I couldn't really tell if there was water there or not. But I drained it for about 45 seconds, started the truck and the warning was gone.
Old Jan 17, 2012 | 11:49 AM
6.7Fan's Avatar
6.7Fan
I guess I should have stated that differently. It doesn't necessarily mean the warning "works," but just that it came on one time because it was either past the threshold of water in the separator or it at least thought it was.
