Sponsored by: Real Truck
DRW Fender Liners
Old Feb 24, 2015 | 07:53 AM
glennemay's Avatar
glennemay
DRW Fender Liners
OK. So New England has not been my trucks friend this winter. Plow went on the end of January and just came off last night for the 2nd time (First time was to replace my alternator) Hoping I get a few weeks to drive around in a plowless truck. It feels like a sports car.
So. here is my question. The truck is an 04 350 DRW. (Same as sig) the inner fenders on the DRW have worked themselves loose and I have lost the plastic push clips that hold them in.
Does anyone have a better solution to holding these in there? I could use a nit and bolt, but figure if that was a good plan, Ford would have done it to begin with. If not, What is the actual name of those so that I can order them. Having a hard time finding the parts.
Thanks
Glenn
Old Feb 24, 2015 | 11:36 AM
droldsmorland's Avatar
droldsmorland
If you do use the nut n bolt set up use stainless steel. Not sure what the fasteners are. Could be christmas trees or push rivets or? The Googler is your friend here.
Google push in plastic rivets. Look at images of what you have and click on the image to follow to web site. Ford dealer will have them. Dorman, NAPA etc...But the Fords will be OEM
Old Feb 24, 2015 | 12:33 PM
scraprat's Avatar
scraprat
Top Answer: 5
I've used the larger zip ties and it has worked ok.
Old Feb 24, 2015 | 02:20 PM
pjcinmi's Avatar
pjcinmi
Ace Hardware also carries all sorts of the push pins and plastic body clips thingy... In the specialty draws in nut & bolt isle.
I also S/S nut & bolted some of mine.
Stroker 1976
Oct 18, 2024 10:07 AM
Megiddo
Sep 13, 2018 01:07 PM
Mikes67F250
Dec 17, 2011 12:12 PM
RickyD
Apr 29, 2005 02:36 PM
cobraguy
Aug 14, 2001 12:25 AM
