Sponsored by: Auxito
Door Ajar
Old Feb 16, 2006 | 05:30 PM
dog2580's Avatar
dog2580
Door Ajar
I have a 99 F-150 extended cab and today I started having problems with the door ajar light not going off with the doors shut, I have searched the forums, went to the FAQ page and I understand spraying the WD-40 into the latch but I dont know where the latch is, is it toward the back of the door where it would make contact with the rear door?? Any and all help would be appreciated.
Old Feb 16, 2006 | 05:50 PM
vancouverpower's Avatar
vancouverpower
If it is like the F250- you will find it in the middle of the rear door. Need to remove the door panel to get at it. I need to clean mine also. On my truck you can see it with a flashlight around the gap of the switch "trigger" that the front door contacts.
Old Feb 16, 2006 | 08:36 PM
alberta46's Avatar
alberta46
you shouldnt have to remove the door panel just spray liberally into the door latch it is the piece at the rear of the door that latches on to the door post
Old Feb 17, 2006 | 01:06 AM
hood's Avatar
hood
dog2580,
Insert the thin plastic nossle from the WD-40 into your door lock cylinders (where your key goes into) and spray liberally. Spray ALL latches and ALL door lock cylinders, on ALL doors. This should cure your door-ajar blues.
Old Mar 5, 2006 | 06:25 AM
LITLEJIMMYNORTON's Avatar
LITLEJIMMYNORTON
Thanks guys; the wd-40 did the trick for my door ajar light. Did just like hood said.
Old Mar 5, 2006 | 09:06 PM
vancouverpower
Yep you are correct, I don't know what switch thingy I saw in the rear door is. Anyways I just oiled the the drivers door latch and all is fixed.
Old Mar 6, 2006 | 08:02 PM
CharlieFoxx's Avatar
CharlieFoxx
Unhappy Door ajar problem
My 97 F150 had the same problem. I tried with WD40. All was okay,...for a couple of minutes. Decided to replace switches. Still the same.
Any suggestions???
CharlieFoxx
Old Mar 7, 2006 | 05:15 PM
alberta46's Avatar
alberta46
Charlie did you do both doors? could be the other one causing problems
Old Mar 8, 2006 | 02:49 AM
Peter_O's Avatar
Peter_O
7th Gear
98 F150 regular cab
I bought the truck today and the door ajar light is on. I tried WD40 and it did not fix it. Not sure if this is related but the interior lights (in the doors) and the cargo light stay on until I get up to about 30kmh. They go off at that point but the door ajar light stays on. Also, when I exit the driver's door the interior and cargo lights stay on. I quickly learned to exit the passenger side but that's a pain. Any suggestions? Thanks
Old Mar 10, 2006 | 12:28 AM
hood's Avatar
hood
Peter_O.....
Give the WD40 another try. Follow the directions in my earlier post....you've got nothing to loose, if it fails then move on to other troubleshooting ideas.
My Sable had the door ajar light and the dome light combined like you. Took 5 minutes with WD40 and all was cured. Be sure to spray ALL doors and latches and lock cylinders liberally...soak em good. Work your key into ALL door locks after spraying. Update us on your progress...good luck.
Old Mar 10, 2006 | 06:53 AM
Never Locked Out's Avatar
Never Locked Out
I am a locksmith now for 30 years and I recommend a product called TriFlow instead of WD40. We use it all the time. If you you lube the locks before washing it will help prevent freeze up as well. You can also use it to lube latches as well.
Old Mar 10, 2006 | 07:51 PM
Peter_O's Avatar
Peter_O
7th Gear
Well persistance paid off. Thanks for the suggestion Hood. All is working now. Where do I find TriFlow so I can be "never locked out"?
Old Mar 10, 2006 | 09:23 PM
Never Locked Out
Never locked out is for web site for our Hitch Safe Key Vault. Tri-Flow can be purchased from most locksmiths or possibly a hardware store. We also sell it and ship it usually by the case. It is about $8.00 for a 3.5 oz can. If you really want to try some and you cannot find it locally. We could ship you a can. Just a note though, shipping one can is almost as much as the product.
Dave
