Engine Swap
Old Feb 23, 2015 | 03:55 PM
dnkensinger's Avatar
dnkensinger
Engine Swap
Hey Guys, I'm sure there's a post here somewhere regarding this but I still haven't figured out how to productively search for such threads so my question is, what's involved in getting a 460 in an '84 250 (currently a 5.0L with 4-speed). What I need specifically is what mounts would I have to use, does a 460 bolt up to the 4-speed... basically, what's needed to adapt the 460 into this bay.
Thanks!
Old Feb 23, 2015 | 03:56 PM
billabongboy73's Avatar
billabongboy73
Motor mounts should be different but what transmission does the truck currently have?
Old Feb 23, 2015 | 04:57 PM
dnkensinger
I wanna say it's the T170FT. For motor mounts, wasn't a 460 offered as an option that year? Can I just buy mounts for a 460 and they should bolt right up to the mounts welded to the frame?
Old Feb 23, 2015 | 05:02 PM
billabongboy73
The transmission you have will not work with the 460. You should be able to just buy motor mounts since yours is a F250.
Old Feb 23, 2015 | 05:57 PM
dnkensinger
Was the 460 offered with a manual trans at the time? If so, which was it?
Old Feb 23, 2015 | 07:19 PM
billabongboy73
ZF transmissions were put behind the 460 motors. Do a search and you will find some very useful info about the zf5 transmissions.
Old Feb 23, 2015 | 08:03 PM
Franklin2's Avatar
Franklin2
You could most likely get a combination that would work with your tranny, but that tranny is very weak, it would never hold up to a 460. What are you planning to do with this truck? Like the other poster alluded to, you need a heavy duty tranny for that engine. They came with t19 4 speeds, if you want overdrive a zf 5 speed would work.
You are correct, if you have a f250, you should be able to find the plates and mounts to mount it up from another f250 or 350. But you may have a small problem; The trucks that came with the diesels and the 460's have a big dent made into the front crossmember for oil filter clearance. If you have a small block f250, then your truck probably doesn't have this dent, and you will need to run a remote filter setup. Even with the dent,, the 460's had a special oil filter adapter different from the cars.
You will have to check your radiator support. See if it will accommodate a 460 radiator. It may not and will have to be changed, not sure though.
Old Feb 24, 2015 | 06:23 AM
RL250's Avatar
RL250
I don't know how much you want to delve into your engine, but a stroker 351 can get you torque numbers close to a stock 460 relatively easily. A 351W bored and stroked to 408 will give you a large boost in torque without the oil filter or trans issues. Additionally, you can still do a zf5 swap on the transmission. Keep in mind that there are two ZF transmissions, the S42 rated for 425ft-lbs and the rarer S47 rated at 475. And some after market rebuilds rated around 45-460ft-lbs.
F-250 WARHORSE
Aug 28, 2011 03:37 PM
igod69m
15
Jan 20, 2010 08:21 AM
treetrunks
Apr 16, 2009 07:28 PM
Frdbuy8589
Feb 2, 2006 02:22 AM
4rdgasm
Jan 5, 2003 06:36 PM
