Computer Chips & Tuners
Help on bronco II
Old Jul 23, 2003 | 09:33 AM
cezarleo03's Avatar
cezarleo03
Question Help on bronco II
I recently purchased an 84 bronco II w/ a 2.8 engine and am having a couple of problems. The temperature dummy light comes on after the engine has been running for a few minutes. I replaced the radiator, head gasket, machined the heads, water pump, and finally the thermostat, and the light still comes on. One side of the radiator (left) gets hot, and the other stays cold. The upper left radiator hose stays hot while the lower right hose goin to the thermostat does not. The thermostat is positioned so that the thermometer is facing the hose and radiator like I have done on all other cars&trucks. Am I putting the thermostat in wrong on this engine??????? I also have a fuel problem. The engine will run and suck fuel from an external gas tank, but not from the gas tank. Replaced fuel pump and attempted to blow out fuel lines. Any ideas??????? PLEASE HELP!
Old Jul 23, 2003 | 09:37 AM
FTE Ken's Avatar
FTE Ken
Help on bronco II
Ummm.... what's you're computer tuning question?
Wren
Modular V10 (6.8l)
May 1, 2012 10:17 AM
Celtic Nomad
15
Sep 1, 2009 06:11 PM
rrumba
28
Jan 27, 2009 08:28 PM
Bobtailfan
Oct 11, 2007 12:05 PM
cezarleo03
Bronco II
Jul 23, 2003 11:02 AM
