Injector Pump failure questions
I already got a working core off craigslist for $80, god I love that site, and a rebuild kit for like $50, and god do I love my part stores account with BD Diesel. She's stripped down, cleaned and I'm in the process of rebuilding it.
My questions this time are what causes them to fail? This one lasted 2 years and was rebuild by a reputable shop, last time it lasted like 4 years in my ownership and some time before but I was WAY down on power before it finally gave up the goat. But this time she still runs like a bat out of hell. Okay a brick shaped bat on 35's with, to quote my uncle, "highway gears".
She isn't down on power at all, it's the fuel economy that is murdering me. I've been using fuelly to keep track of my fill-ups and economy and I've been averaging between 17-19 unloaded with a mix of city highway. Now I'm lucky to get double digits. Weirder still I got close to 14 when towing my wife's escape around town and on the freeway to my shop and the rental trailer back, than I do driving around empty. Costing me about $10-15 in fuel a day commuting. So it got depressing to monitor economy and I stopped.
Is there any insight that people have on these pumps?
It's cheap to fix! Way easier than an IP rebuild. : )
-Joshua
If what you suggest is the case I have some questions as I've run this IDI timed properly and not timed properly and it still performs great with the exceptions of starting and economy.
First of all without some outside stimulation how would the timing change? (sure with time you'll see it to go slightly off but I can't see it being substantial in just two years), and secondly how would it affect the thermostat causing failed starts? While the thermostat is in the upper chamber and it does receive a good amount of heat I can't see how any adjustments made to the timing below would have an inherent effect on it, unless it is going to suddenly make a drastically reduced amount of heat. It isn't like it is dumping fuel early and causing a large amount of unburnt fuel to escape, if that was the case I'd just retard it. There isn't any real stumble of it getting fuel late either, nor is there any (not a misfire, but I can't remember the right word for it) which would signify air in the lines.
And $80 for a working core and $50 for a rebuild kit is pretty good, as the best deal I could find last time was $675 for a rebuilt IP.
Last edited by SnuffthePunkz; Feb 22, 2015 at 11:06 AM. Reason: Words, english, hard?
I'll take a photo or two for this one, but until I'm certain of how to do it and wont cause engines to grenade, I won't be posting any instructional info.
But here is a link to the service manual that I'm keeping open on my phone. It is hosted on my OneDrive, it isn't 'exact' but it is close enough that any questions I have can be figured out based on the likeish pictures.
http://1drv.ms/18ez6gH
Here is a very short lived thread with info on rebuilding them.
DB2 Injection Pump Manual/Parts Illustration? - Diesel Forum - TheDieselStop.com
Most of the links from it work, but I think one doesn't.
Yes you can take a perfectly running pump that leaks like a sieve and re seal it, thats not hard, I've done it, but to actually make a worn out pump work again will require hard parts like metering valves, rotor and head assembly (roughly $6-800 a pop!!!) transfer pump vanes/assemblies, over size servo advance pistions and something to ream the housing over size and to smooth shape, new over size plungers, a flow bend, ect... and if you think a drill bit is your friend in these pumps, walk away now before you sell one to someone and the metering valve gets stuck wide open and causes an acident.
Have fun with your own personal truck and parts, nothing wrong with you wanting to fix your stuff, these pumps are really easy to understand and take apart, but please don't be tring to offer a rebuild pump service, it won't work.
Thats what make a rebuild a rebuild instead of them ebay people that end up into the hall of shame/ ripe off sellers.
Have fun with your stuff and post how your reseal kit goes.
Sorry for any confusion that I may have caused I know entirely that it is resealing and does not include boring out to remove worn or damaged parts. I may have said rebuilt in error, as it is a commonly misused term in smaller equipment.
I'm on my phone so I can't really hit on all your points, but ill look at it more in depth when I get home.
Also if you spent an hour talking to the guy that I work with you'd laugh, feel silly and take back what you said, just saying.
