Alternator wiring...
Old Feb 21, 2015 | 05:56 PM
christaylor's Avatar
christaylor
I have been having the super high/low voltage issue with my alternator and finally had a chance to dig into it today. Looking up the info on AllData Pro, they show a 3 wire connection and a 2 wire connection...
I have two wires at the alternator. i will be honest, electrical components and I are not friends... I see some pretty bad corrosion at the "plug" side on pin 1. I have a donor truck in mind that i may be able to get a new plug from and wire it in.
I have seen that the issue is usually caused by a broken wire, but where is ti usually broken? it goes from loom to loom and I don't want to tear into it all if I don't have to.
Thanks for any help, in advance.
Old Feb 21, 2015 | 06:51 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Pin 1 is voltage KOER
Pin 3 is voltage at all times
If Pin 1 is broken/chafed the alternator will not charge
If Pin 3 is broken/ chafed the voltage will fluctuate from 13-15.
Pigtails are available new from any parts store.
Josh
Old Feb 21, 2015 | 06:59 PM
christaylor
Good to know I did not think the pigtail would be do readily available
The pigtails I see on line have 3 wires, just cap the middle wire?
Old Feb 21, 2015 | 07:02 PM
Bullitt390's Avatar
Bullitt390
It isn't used, just cut it off at the connector.
Josh
IDI-Charlie
Electrical Systems/Wiring
Apr 2, 2014 10:24 PM
lio45
Aug 24, 2012 11:40 AM
robs01f250
Dec 15, 2010 12:47 PM
RRGUFFIN
May 7, 2007 10:48 PM
dustinleavitt2000
Jun 22, 2003 02:44 AM
