By far the easiest is going to be a warmed up 300. It will use everything you have already so you won't have to get any more parts.
If you want somebody to educate you on the subject, talk to ford_six, and Trozei. They can tell you how do you build a good 300.
2X First Prince. If it were me I'd rather spend the money in a JY 300 engine rather than everything else around a 360/390. Since you already have a 240 you have the cylinder head that will wake up a 300 a bit.
That depends entirely on how much money you want to spend and whether or not you build the engine as a whole or simply throw parts at it. There's a guy with a 500hp NA 300 that he's spent an excessive amount of money building, or there's the typical guy who buy a cam, intake, and carburetor and gets maybe 225hp on a good day. The power you can expect therefore depends on your definition of "good."
Indeed, so let's say OP does the basics. Carb intake cam exhaust. With a .030 over bore and good Pistons. 240 head that he already has. If he gets 225HP that's a good 100HP more than what his worn 240 is putting out. And the torque will increase even more.
OP, how does doubling your motor sound? Build a decent 300 and that's what you'll do.
I have to agree with what the majority is saying. I would definitely look into building a 300 I6. Great low end torque, unbelievably reliable and very low maintenance. Ive heard many horror stories of people abusing the little 300's and they just won't stop ticking. If I knew a 300 I6 would bolt up to my transmission I would have put one in there long ago.
I hope I am not stepping on this thread to ask.....are there any "gotcha's" with the 240 to 300 swap in my '67 F-250? Is the flywheel a straight swap from the 240 to the 300? I am going to pull the trigger and order a 300 carbureted long block today. I see some options for oil sump location. Were there differences in the pump pick-up. I find it hard to believe that the pump location would have changed.
I've heard they do In the cold climates. But I also heard they were going all diesel. I know all the trucks on my route are diesel.
Here in NC UPS has gone back to gas engines. I asked the driver after I saw him pumping gas at a local station. I thought they all were diesel, and depending on fuel cost they may be different in the greater US of A.
Pump location is dependent upon sump location.
The 240 and 300 are identical except for the crank, rods, and pistons. Nothing else needs to be worried about. Put the 240 head on the 300 though and you'll get better compression. While the engine is out of the truck, put some later year EFI exhaust manifolds on and you'll get an engine that breathes so much better than it would with the factory log manifold. Both of the previously mentioned tips are either free or cheap and they give you benefits all around from power to efficiency. Get extra fancy and use the 240 rods with SBF 331/347 stroker pistons and you'll have a quicker engine with less piston slap, but then you're talking money.
302 would be easiest. I'd get a EFI engine from the late 80s early 90s
I have a 1969 360 3 speed and I would like to get a 302 but without changing transmission I was wondering if I could just change the bellhousing or just bolt it on? thanks.
You need to change at least the bell. FE used a different pattern than SBF. A C4 or AOD would be the tranny to swap in.
