Computer Chips & Tuners
93 f250 ECU problems?
Old Feb 21, 2015 | 02:31 PM
TigRigWelder's Avatar
TigRigWelder
My 250 has been acting up. Smells like it's burning a lot of fuel. It bucks when I put it into drive. My transmission has no idea what it's doing.
I took it to a shop to have my trans looked at. They couldn't get any data from my drivetrain mod.
I was told its either bad wiring or my ECU is bad
Has anyone else had these problems??
Any information will be much appreciated before I replace it lol.
Old Feb 21, 2015 | 07:24 PM
Conanski's Avatar
Conanski
Try to do a self test on the PCM, you should at least get the 11 or 111 codes on the check engine light, see here for more info.. Fuel Injection Technical Library » How To Run a Self-Test
Old Feb 21, 2015 | 07:46 PM
TigRigWelder
I will defiantly try that tomorrow thank you! I pulled
Old Feb 21, 2015 | 07:47 PM
TigRigWelder
I will defiantly try that tomorrow thank you! I pulled out the computer today and checked the board and it looked very clean and no corrosion. Not sure if it was remanufactured or what. I cleaned up the connections just to be safe and put it back in
Old Feb 21, 2015 | 08:29 PM
TigRigWelder
I can't get anything from the self test plugs. I'm not getting any data at all
Old Feb 22, 2015 | 07:40 AM
RIKIL's Avatar
RIKIL
even though your board looked good, some components may be bad. get a new one
TigRigWelder
Feb 24, 2015 12:27 AM
joel_93f250
16
Aug 2, 2014 10:17 AM
amer28
Dec 4, 2010 10:09 AM
ccw215
May 22, 2007 09:56 PM
carpe_diem
Electrical Systems/Wiring
Aug 3, 2003 06:06 PM
