Tooth count for starter
Old Feb 21, 2015 | 09:45 AM
candoo's Avatar
candoo
I am looking at a after market starter and need to know the tooth count for my 1966 F350/352ci/4spd NP435. Everything points to a 164 tooth but I would like confirm this.
Old Feb 21, 2015 | 09:55 AM
TA455HO's Avatar
TA455HO
Lead Gopher
A flywheel might have 164 teeth but I've never seen a starter for a car or truck with even a quarter of that. The starter for my 300 six has 9 or 10 teeth. 352 starter has to be close to that, too. They are small gears so no way 164!teeth would fit.
Flywheel could have 164 teeth so maybe they are referring to what the starter meshes with. In that case probably correct.
Old Feb 21, 2015 | 10:40 AM
candoo's Avatar
candoo
I was refering to the flywheel tooth count.
Old Feb 21, 2015 | 03:23 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by candoo
I am looking at an aftermarket starter and need to know the tooth count for my 1966 F350/352ci/4spd NP435.
C5AZ-6384-A .. 3/4 M/T Flywheel Ring Gear-184T / Obsolete
1965/67 F100/350 352 / 1968/76 F100/350 360/390 // 1965/71 352/390/410/428 Ford/Merc Passenger Cars.
ALL 1963/76 FE engines with A/T & M/T use the same 3 hole starter and starter drive.
btw: 164T ring gear: 221/260/289/302/351C/351W
Old Feb 21, 2015 | 03:27 PM
candoo's Avatar
candoo
Funny you should mention that, I just relized a few minutes ago my mistake from the literature. Thanks for the info I will go ahead with the 184 spec.
jowilker
Apr 13, 2021 01:00 PM
SixtySix Ford
Aug 28, 2010 07:53 PM
marty68
15
Nov 20, 2009 03:03 PM
Blue50F-1
Jul 20, 2009 07:14 PM
fordredneck300
Jul 14, 2005 08:56 PM
