2000 F250 Stalling
Old Feb 24, 2015 | 12:49 PM
whitetmw's Avatar
whitetmw
Testing CMP, the Batteries should be fully charged, the GP Signal wire disconnected and ALL Accessories OFF.
A Digital Multimeter that can read Hertz Frequency (Hz).
You'll need someone to help you crank the car's or truck's engine while you observe the readings on the Multimeter.
* A Fuel Injector Noid Light also works well
Scan Tool monitoring FPW and RPM
An Oscilloscope is the way to go. See known good reference signal below.
Process:
Back probing pin #90 should read 0.2 VDC to 5.0 VDC (Reference Voltage) - No Voltage? Suspect PCM or Wiring Issue
Back probing pin #21 should read 12 VDC / Hz
Back probing pin #65 Using OHM, should read infinite. Resistance? Suspect PCM or Wiring Issue
booger47
Oct 25, 2017 02:27 PM
RedDevil460
Aug 12, 2016 06:07 AM
ultraclyde
Jan 12, 2016 09:30 AM
tsmall07
Oct 23, 2014 12:13 PM
mkmathis76
13
Apr 14, 2008 02:35 PM
