CRRRAACK.....!
Old Feb 24, 2015 | 03:47 AM
  #31
Amish Ford's Avatar
Amish Ford
Yeah, it's yellow (crappy) limestone, mixed with silt clay. Dirty, nasty, DUSTY stuff. Wet or dry, it gets everywhere. A couple of Amish kids washed HALF of my other truck on Saturday....put about 25 miles on it since, and you can't tell one side was ever washed....In the summer, a BICYCLE raises a cloud of dust.
Old Feb 24, 2015 | 06:26 AM
  #32
Franklin2's Avatar
Franklin2
Originally Posted by RL250
True, but rust is not an issue then. I've had some very old vehicles and some very rusty ones (not always the same vehicles).
You never had a aluminum wheel stuck to the rotor or brake drum? It's a big problem with some of the OEM aluminum rims.
Old Feb 24, 2015 | 07:10 AM
  #33
Amish Ford's Avatar
Amish Ford
I dunno....I'd rather have a tire guy ruin a stock steel rim that costs $75 to replace, then a fancy Aluminium one that cost $200-$300 or more....Besides, I ain't going for LOOKS, I just need them to keep rubber between the truck and the ground.
Old Feb 24, 2015 | 07:14 AM
  #34
Amish Ford's Avatar
Amish Ford
The neighbor kid had a flat a couple of months ago. It was on an Exploder with aluminium rims. He called me to come look at it. He had it jacked up, lugs bolts off, and the wheel would NOT budge. Had to take a big hammer and a block of wood. He held the block, I SMACKED it with the hammer. It busted loose after 3 hits....
Old Feb 24, 2015 | 08:58 AM
  #35
raytasch's Avatar
raytasch
Believe Nothing
I had new tires installed on an E450 super duty with Alcoa wheels several years back and they had a hard time getting the wheels loose from the hub. They had two guys working on it with a big pry bar between the duals to break them loose. And, this was at a Ford dealership.
Old Feb 25, 2015 | 02:55 PM
  #36
f100beatertruck's Avatar
f100beatertruck
My plow truck came with aluminum rims. I had to attack two of them with a sledgehammer to get them off. They would not even think about moving, even with a 3lb maul. I had to use an 8lb sledge and not be kind about it.
Truck has steel rims now...
Old Feb 25, 2015 | 07:36 PM
  #37
Ranger1980's Avatar
Ranger1980
AntisieZe works great for that.
Old Feb 25, 2015 | 08:42 PM
  #38
RL250's Avatar
RL250
The black rims on my Nissan are Pro Comp 16" steel wheels. $80 a wheel. Nissan 16" wheels would have set me back twice that. The F250 is getting some custom ones from XD wheels.
Old Feb 26, 2015 | 07:36 AM
  #39
Amish Ford's Avatar
Amish Ford
BUT....rims for a DUALLY are a different monster...
Old Feb 28, 2015 | 08:35 PM
  #40
RL250's Avatar
RL250
I am not denying that. Driving a dually is a different monster. And I thought 5-tons sucked to drive.
Still, look up KMC wheels. They offer truck rims for duallies as well. I think you can even get the Rockstar XD's in dually.
Old Feb 28, 2015 | 09:24 PM
  #41
Amish Ford's Avatar
Amish Ford
The only 1986 F350 listed on the KMC website is "SRW". I ASSUME this stands for "Single Rear Wheel".........
Besides - them are some UGLY wheels!
Old Mar 1, 2015 | 12:00 AM
  #42
RL250's Avatar
RL250
Any rims for the 95 F350 should work. The Super Duty remodel was the main change in wheel lug pattern. I can't confirm how far back the 8-6.5" circle dates.
Old Mar 1, 2015 | 06:20 AM
  #43
Diesel_Brad's Avatar
Diesel_Brad
Correct. Any wheel from an 80-97 F350 dually will work.
here is stock looking ones from Eagle Alloy
http://www.aewheel.com/eagle_alloy_w...d=4302&cat=474
Old Mar 1, 2015 | 07:32 AM
  #44
Amish Ford's Avatar
Amish Ford
OUCH! Even if I liked the looks of any of those, NO WAY coud I justify $1500 (or more) for rims that would get torn up from use. This truck spends most of it's life hauling on dirty, dusty, nasty rock roads (see original post photos....). They'd look good for AWHILE, but not very long. I will stick with stock steel rims.
Old Mar 1, 2015 | 04:40 PM
  #45
raytasch's Avatar
raytasch
Believe Nothing
Series 058 Dually - Dually - Eagle Alloy Wheels
Somewhere around '84 or '85, Ford went from a lug centered wheel to a hub centered.
aaronbob
WTB - Parts & other
Mar 22, 2016 05:27 PM
Connecticut Calvin
Ford Truck Parts for Sale
Jun 9, 2015 03:28 PM
canister
33
Apr 24, 2010 08:43 PM
ki4knd
Jan 25, 2009 12:27 AM
masterbeavis
16
Feb 24, 2008 03:17 PM
