Sport Trac HVAC Blower inlet blocked?
Old 02-19-2015, 07:18 PM
ZeroAviation's Avatar
ZeroAviation
ZeroAviation is offline
Been on this forum for almost a year, first post ... So I just picked up a 08 STL.
I noticed that it doesn't get a lot of airflow out of the vents or floor. I initially thought that it was door actuators. I checked the vacuum at all of them and they all cycled as required.
I also checked the blend door, and the fresh air doors as well. They all cycled as desired. When I was checking my fresh air door with the borescope, I noticed a layer of... insulation maybe? on top of the inlet for the blower. So I removed the blower, and the picture below is looking up into the housing. Is that supposed to be there? It appears extremely dense, so I am led to believe thats what is causing my flow issues.
If it does not belong, any ideas on how to remove it? Where is the fresh air inlet on this thing?
Full size : http://s4.postimg.org/a1fhaq9d9/IMG_20150219_181910.jpg
Cheers,
-Matt
Old 02-19-2015, 08:24 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
kind of looks like a mouse nest built out of carpet fibers.
Old 02-19-2015, 09:20 PM
ZeroAviation
The sport trac doesn't have carpet... So is it safe to say that doesnt belong lol
Old 02-20-2015, 11:09 AM
steve(ill)'s Avatar
steve(ill)
looking at the photo it actually looks like it was original, but im trying to figure out what purpose it could serve. You should be able to figure out the flow path of the air. Sure looks like it would go thru that hole... I would be looking for a way to get it out and test.
Old 02-20-2015, 11:13 AM
steve(ill)'s Avatar
steve(ill)
here is another idea? or at least access to the inside ?
How to Change Cabin Filters in a Sport Trac (6 Steps) | eHow
Bronco Billy
2004 - 2008 F150
10-11-2017 04:41 PM
wmbster
07-22-2013 08:45 PM
wmbster
07-22-2013 12:08 PM
mkoppler123
10-30-2012 08:44 PM
cookie88
40
09-17-2006 12:04 AM
Quick Reply: Sport Trac HVAC Blower inlet blocked?
