What happens on max a/c? - Ford Truck Enthusiasts Forums
Old 08-24-2006, 10:20 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
With the fan on high and normal a/c selected everything is fine. When I switch to max a/c the blower gets loud behind the dash but the volume of air out the vents is cut in half. The air does get colder, so I know it's doing the recirc thing, it just doesn't blow as hard as it's supposed to.
Haven't ripped the dash out yet....kinda hoping someone can give me clue what's happening in there before I do. I hate HVAC problems.
Old 08-24-2006, 10:40 PM
Uzumati's Avatar
Uzumati Uzumati is offline
Uzumati has a good reputation on FTE.Uzumati has a good reputation on FTE.Uzumati has a good reputation on FTE.
Sounds like a vacumn leak when the volume drops does air come out the defrost vents?
Check post 13
https://www.ford-trucks.com/forums/5...heel-well.html
I can shoot you a pdf with the diagrams if you need it cookie
Old 08-24-2006, 10:52 PM
cookie88's Avatar
Nope. Defrost, vent, heat.....every position works exactly as it's supposed to. The air that is not blowing out the vents is not blowing out anywhere...not the defroster, not the floor.....it sounds like the blower is ramping up up like crazy, it just doesn't make it out.
I appreciate the offer, but I've got the schematics already. I'm trying to figure out what the blend door is supposed to be doing and what the little actuator thingamabob under there is called.
Old 08-24-2006, 11:06 PM
Uzumati's Avatar
Blend door should be closed (no vacumn) on Max AC. I cant find anything on the actuator.
Could the blower be clogged - blower spinning up but cant pull enuff air would make a heck of a racket
Old 08-24-2006, 11:09 PM
Uzumati's Avatar
AC Max door positions
Old 08-24-2006, 11:12 PM
ccg711's Avatar
ccg711 ccg711 is offline
ccg711 is starting off with a positive reputation.
this sounds stupid, but reach up in the intake vent and make sure it's clear (blower off i imagine) i've done this several times to my Stang. wally world plastic bag from floor board gets sucked up (i live in my vehicles and they are quite cluttered), happened twice that I can think of. haven't taken a look at truck or schematics, but i would imagine recirc intake is in passenger floorboard. just a thought.
Old 08-25-2006, 01:27 AM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Cookie,
What you're describing is exactly what mine does. Max A/C reduces the airflow.
I thought it was "normal". We'll see, however.
Pop
Old 08-25-2006, 04:03 AM
ryaneverk2's Avatar
ryaneverk2 ryaneverk2 is offline
ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.
On mine, if I switch from A/C to MAX A/C, without changing fan speed, the airflow increases... as well as gets colder. So, Max A/C blows harder than plain A/C, all else being equal, on my truck.
Old 08-25-2006, 05:53 AM
Markadeck's Avatar
Markadeck Markadeck is offline
Gone, but not forgotten
Markadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant future
Every vehicle I have ever owned the vents have put out more air on Normal that on Max.
Old 08-25-2006, 11:14 AM
jtharvey's Avatar
jtharvey jtharvey is offline
jtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to all
Mine's like Ryan's - on Max it feels as if it blows harder, and definately colder.
Old 08-25-2006, 11:32 AM
Markadeck's Avatar
Quote:
The colder I will buy for sure, but I think the harder is tricking you. It is nearly phsically impossible to blow harder because it is recirculating the cab air instead of sucking it in from the cowl area.
Old 08-25-2006, 12:05 PM
zx250's Avatar
zx250 zx250 is offline
Of the next Riffraff East
zx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant future
Just come in from checking mine. With fan on high, when I go from normal to max, the fan DOES blow quite a bit harder. Sounds like fan speed increases as well. It feels as if it is moving half again if not twice as much air.
Old 08-25-2006, 01:12 PM
ballbandit ballbandit is offline
ballbandit is starting off with a positive reputation.
I worked on a sport-trac one time that had dead squirrel in the duct.I took the blower motor out to discover this critter. Something you might want to check.
Old 08-25-2006, 01:26 PM
Markadeck's Avatar
Quote:
I've a better one than this. I have a T-Bird Super Coupe that sometimes sits for a year at a time without being driven. A family of mice moved into the housing, nest, pieces of paper towel, dog food for emergencies I guess. What a mess. I remember cutting the hell out of myself getting the damn thing apart and back together.
Old 08-25-2006, 02:07 PM
ccg711's Avatar
max should blow more than normal due to the fact that it's not trying to keep positive pressure on a cab that is more sealed than open. crack a window and normal ac might blow more since it is now free to blow air out the cab. definately sounds like an obstruction.
Overheating/Excess coolant pressure, only on Max A/C Wren Modular V10 (6.8l) 6 10-10-2013 07:33 AM
Max a/c cutting out Byf619 1997-2006 Expedition & Navigator 25 05-04-2012 04:06 PM
'95 powerstroke a/c problem PowerstrokeDude 1994.5 - 1997 7.3L Power Stroke Diesel 9 09-21-2006 11:28 PM
a/c don;t blow out vent but is still blowing bigman7474 Cooling, Heating, Ventilation & A/C 5 07-17-2005 09:12 AM
"norm a/c" works OK... but no "max a/c" koalamazed Aerostar 3 07-09-2004 04:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
