Dash
Old Feb 21, 2015 | 04:22 PM
  #31
greentruck72's Avatar
greentruck72
ok my pump is quiet and works well, just one more thing to check, the truck also hasn't had an alignment in 20 years+ so should I try that?
Old Feb 21, 2015 | 04:26 PM
  #32
greentruck72
or should I do that afterward,
Old Feb 21, 2015 | 04:30 PM
  #33
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Front alignment AFTER the king pins replacement, and doing a wheel bearing insp and repack. Also insp the tie rod ends very well too. I suspect the steering box is worn out.
Any of that that needs replaced do it and the alignment last.
Old Feb 21, 2015 | 04:35 PM
  #34
greentruck72
ok sounds good, you don't happen to know an easy way to remove king pins do you?
Old Feb 21, 2015 | 05:10 PM
  #35
77&79F250's Avatar
77&79F250
Easy way NO, special tool to make it easier that you can rent from most auto shops, YES.
Old Feb 21, 2015 | 05:48 PM
  #36
greentruck72
tool? that may need some looking in to.
Old Feb 21, 2015 | 06:12 PM
  #37
77&79F250's Avatar
77&79F250
Yes I see the tool kit is $$$, maybe you can rent one?
Med1455
Apr 1, 2016 08:56 PM
wameyer
Feb 3, 2014 01:36 PM
granny_rocket
Apr 29, 2013 06:50 PM
myutesux
Apr 12, 2010 04:30 AM
wintremute
Apr 17, 2006 03:12 PM
