What carb should I buy
Look into Holley double pumpers. I was amazed at how much information there is available on them. Not to mention every part can be easily bought for them. If the engine isn't too far from stock a 600 or 650 should be more than enough to put some pep in your trucks step.
Keep in mind that you'll have to swap out intakes if it hasn't been done already.
I put one of these Summit brand carbs on my 77. Pretty good for the money. Worked really good right out of the box. I may try to tune it later but right now it's working great for what I do.
http://www.summitracing.com/parts/su...00vs/overview/
I have a quick fuel slayer series on mine and I love it. Gives you a few more options for tuning that the other carbs may not offer. From what it sounds like, you probably dont need a double pumper. A vacuum secondary will be just fine.
I have a quick fuel slayer 750 with a vacuum secondary and electric choke on my 390 and my motor has a lot of pep in its step. The link below I thought was a great resource, not only for efficiency but for dollar value.
The Great $299 Carburetor Shootout - Car Craft Magazine
I would like to get more power, I don't wanna totally kill my mpg even though I'm sure it's not great anyhow. As far as mods I think the engine is pretty stock. I've done a exhaust but this will be the last mod I'm sure to this engine. Diesel later in a year or so but the current carb needs to be rebuilt so I figured I'd just replace it.
Then you should stick with a run of the mill 650 or try to find a used one on craigslist or something. 600 and 650 carbs are always forsale at local swap meets for cheep. I found one a local show for $20, did a quick rebuild on it, its good to have a spare I figured.
I had a 750cfm demon on a built 454 in my 59 Cadillac and have to say it was a hell of a ride but between the small gas tank and the price of 91 here in so cal it was also was a hell of a hole in my pocket at the pumps which I'd like to avoid since this isn't a hot rod but I appreciate everyone's input I've got some hunting ahead of me since I'd like to have it running again asap
