external trans filter
I will let the new upgraded filter do 100% of the work--just my .02
2006 F350 4X4
I don't know why getting information out of you is like pulling teeth. If you don't want to share that's fine but I'm not sure why you bother posting at all? If you're going to call me wrong then the least you could do is explain.
In dealing with Mark over the past several years, I've learned that he is short and sweet and to the point.
I'll try to condense the few posts that Mark has made here:
New internal filter has a lower micron rating than the external.
Internal filter filters 100% of the fluid, unlike the external.
Some engineer, who Mark evidently respects enough to believe him said it's better this way.
I'm willing to bet the he doesn't have the answers to the rest of your questions, nor should he. And he doesn't have to explain why or why not.
Minor forum etiquette lesson: If ANY user posts something but doesn't fill in the details, or fails to answer all of your questions, you can safely assume one of two things: They don't have the TIME to do so. OR don't have that information. You shouldn't get your feathers ruffled because a user does either one of those things.
You can politely ask the collective, and you might actually get a reasonable answer. But Mark may not be able to give all those answers to you, and you shouldn't expect him to
Is there any reason this was needed? Was there a specific problem arising because it wasn't being filtered enough? What is improved about it if you don't know what the micron rating of either one was? Was there ever any factory testing of either type of filter you can tell us about?
So we just remove the external filter from the housing on the frame rail and screw the housing back together completely empty?
That's what I'm gonna do. Be nice to replumb but I won't go that far at the moment.
Would you clarify? I remember in a past posts, you indicated that there wasn't a need to replace the internal filter on a 5r110, especially with the external filter added on.
Here you say there's a new internal filter that seems to be a new and improved version.
If that's the case, when did this "new" filter come in factory trucks and what year's need a retrofit?
Thanks.
Mark,
Thanks.
Thanks.
Some people consider it an upgrade.
It is probably like the 6.4L starter, which is an upgrade to install one on our 6.0L trucks, but it certainly doesn't seem necessary for most.
I respectfully disagree.
People ask me at times, how I'm doing?
My response is either "great, I'm vertical today" or "I woke up on the right side of the dirt."
My mom taught me a long time ago, "the only people who don't have time...are DEAD people.
If it's important enough to you, you'll find the time!"
#28
Because I'm difficult. Deal with it or ignore me. It's the same to me either way.
Mark,
Thanks.
Thanks.
You can improve the filtering on a pre-Job#2 2008 5R110 by changing the internal filter and pan to a Job#2 2008 pan and filter.
If you don't change to the newer pan and filter, you need to change the external filter as indicated in the owner's manual. The pre-Job#2 2008 5R110 internal filter only needs to be changed when the transmission is rebuilt. The newer filter needs to be changed, but I don't have the service interval.
#29
"Improve the product" doesn't mean the same as "filter the oil better".
As you suggest full filtering could stop solenoids from sticking, among other things. Does that mean the in pan filter is of a higher micron rating? Not really.
It is possible that you could gain even better filtering by keeping the old style filter and the new pan filter at the same time. Nobody can say yes or no without knowing the micron ratings. I will see if I can ask the manufacturers.
Is it not bad forum etiquette to say "you're wrong" without providing any reasons or proof?
Again, there is nothing wrong with asking a person to elaborate. I told Mark he didn't have to answer if he didn't want to. But there is nothing wrong with asking.
So am I. And everybody seems to have their panties in a twist because I dare ask you to elaborate, because oh gawd, you once worked for Ford. I am so sorry your majesty. From now on we will all take your advice blindly, no explanation is needed.
To be honest I don't think you care while I've got moderators PMing me and some other guy who didn't even help in this thread crying in the corner reporting posts that haven't broken any rules.
#30
There was A LOT of factory testing of both filters. I wasn't responsible for any of that, so I don't have details. The engineer that was responsible told me this change was made to improve the product.
Yes.
None of them need a retrofit.
Yes.
