garage door opner
Old Feb 18, 2015 | 07:41 AM
GORDEN1234's Avatar
GORDEN1234
garage door opner
anyone else having trouble with the sun visor door opener not working until almost 200ft of the door,any adjustments??
Old Feb 18, 2015 | 07:53 AM
QwkTrip's Avatar
QwkTrip
And 200 feet isn't enough for you? Always coming in hot with cops on your tail?
Old Feb 18, 2015 | 07:59 AM
GORDEN1234's Avatar
GORDEN1234
cops and blue lights
that is a good one the siren will tell the wife to get the door up fast because my remote will not work right.
Old Feb 18, 2015 | 08:26 AM
BIGRED 7.3L's Avatar
BIGRED 7.3L
I have the same issue except I can't get it to be consistent 20ft away. I am going to clear out the code and reprogram to see if it gets better.
Old Feb 18, 2015 | 12:32 PM
nynd's Avatar
nynd
200ft would be awesome.. 20... probably normal
Old Feb 18, 2015 | 12:40 PM
BIGRED 7.3L
I'll shorten it to 3 feet. I can pull up to the door and it won't open consitently. I have two other vehicles with Home Link and don't have this problem. I think 20 feet would be ok. anything less seems less than desirable, especially if it does better in my other vehicles. We will see if a reprogram will make it better.
Old Feb 18, 2015 | 07:22 PM
QwkTrip's Avatar
QwkTrip
My wife always yells, "Look out! There's a cop!" Thing is I never speed and use cruise control most the time. I literally have no reason to be concerned about a cop. Her paranoia makes me wonder what she is up to all the time!
Old Feb 18, 2015 | 07:36 PM
cdestuck's Avatar
cdestuck
I know sometimes flipping my visor down vertical will help.
Old Feb 20, 2015 | 04:44 PM
GORDEN1234's Avatar
GORDEN1234
homelink door opener
i called homelink today they help me reprogram the homelink was no help,i explain the broblem to them and they say there is some interference with the signal, maby some led lights,
Old Feb 23, 2015 | 06:11 AM
redford's Avatar
redford
FTE Leadership Emeritus
If your normal garage door remote is working the same way, I would accept that diagnosis.
Old Feb 23, 2015 | 09:14 AM
GORDEN1234's Avatar
GORDEN1234
door opner
pull the visor down about half way and the opner will work a lot better,the new design of the 2015 interior put the visor a little more up into the head liner and it can not reach as far,,
Old Mar 9, 2015 | 02:35 PM
Camulos's Avatar
Camulos
The range on it seems to be very short for me. I usually have to be within 10-20 ft of the door to get it to work. Any further than that it will raise the door part way and it will stop. If I hit it again it will raise the door a little again and stop.
Now if I get to about 15ft away it's guaranteed to open it all the way first time.
Old Mar 15, 2015 | 06:35 PM
Paul_Bukowski's Avatar
Paul_Bukowski
Unhappy Same issue here
Several times, I've reprogrammed my garage door control. It seems to work fine initially after that, but when I leave and come home, the door won't open. That is with the truck parked directly in front of the door, maybe 25' away from the opener head unit. I've resorted to keeping the old transmitter remote in the truck, so I can get in.
So, parked right under it inside the garage, it does seem to open/close the door ok. So from outside, it's very intermittent. I will try lowering the visor into a vertical position, to see if that helps radiate rhe RF better.
TyWebb
6.7L Power Stroke Diesel
18
Dec 29, 2010 11:26 AM
Charles Wulf
Dec 13, 2010 10:42 PM
Big-Red-Lariat
2004 - 2008 F150
Jan 1, 2007 08:43 AM
kpwall
Garage & Workshop
Feb 7, 2006 06:31 PM
uk1050
Apr 1, 2004 10:35 AM
