Sponsored by: Real Truck
Autohubs Not Working
Old Feb 17, 2015 | 06:40 AM
CollinsCD's Avatar
CollinsCD
I decided to take my truck to work today since we got about 6" of snow this morning. Heading down my road, my back tires were spinning very easily so I decided to engage the 4wheel high switch. I back off the throttle and hit the switch for 4 wheel high. Came up to a stop sign on a slight hill and could not get going without getting the truck sideways. I could tell my front wheels were not engaged. I got out and manually move the hubs and pulled away without any problems. So once this artic weather breaks, looks like I will be doing some investigation on why the auto hubs are not working.
Just my morning rant for the day!
Old Feb 17, 2015 | 07:23 AM
senix's Avatar
senix
Could just be the temps...or a vacumn leak.
auto hubs don't work so well when really cold, below freezing temps.
Old Feb 17, 2015 | 09:15 AM
CollinsCD's Avatar
CollinsCD
I'm hoping it has to do more because of the weather. We have had some really cold days here and it is not going to get above freezing until after this weekend.
Old Feb 17, 2015 | 09:41 AM
senix's Avatar
senix
same temps here. Some reports were saying -12F Thursday over night.
Old Feb 17, 2015 | 09:52 AM
tim.moman's Avatar
tim.moman
Temps always get mine. I have replaced everything there is, they work flawless until that early cold morning. Once they are worked usually will function after that. Sounds like others as well feel our pain. lol
Old Feb 17, 2015 | 10:31 AM
Thomas D.'s Avatar
Thomas D.
Anything below 0 degrees I just keep the hubs locked in, which is pretty much all winter. I've been sadly disappointed with my "shift on the fly" **** too many times when its really needed. As long as the hubs are locked the actuator works at all temps. At least down to -56. Been that way since it was brand new. And i expect my new F-450 will be just as finicky with cold weather. Still prefer the dash switch to the floor mount shift.
Old Feb 17, 2015 | 11:04 AM
CollinsCD's Avatar
CollinsCD
Can you leave the hubs locked and still drive highway speeds? I'm sure by the time I get out of work today, the roads will be cleared so I won't need the 4-wheel.
Old Feb 17, 2015 | 11:12 AM
Thomas D.'s Avatar
Thomas D.
Can you? Yes. Should you? Opinions may vary. I do because of necessity. Our road conditions here change by the mile and by the hour. Our highway speeds around town don't exceed 55 mph. Your owners manual does have recommendations.
Old Feb 17, 2015 | 12:16 PM
CollinsCD's Avatar
CollinsCD
I won't be getting over 55 that much so I guess I will leave them in until I get home. Knowing my luck, I will unlock them before I leave from work but will need it locked back in when I get closer to my house.
Old Feb 17, 2015 | 12:20 PM
xmontex4's Avatar
xmontex4
When mine were stuck engaged I was commuting 60ish miles a day (30 both ways) on the highway going 60-70 without issues and also I had no choice since it was my only vehicle at the time and my auto hubs were stuck lol. I just tried to avoid full lock because the front will bind and it sounds nasty. I did that for about two weeks until I got some Mile marker hubs in and never had an issue.
Old Feb 17, 2015 | 01:20 PM
senix's Avatar
senix
I'd leave them locked.
Old Feb 17, 2015 | 06:57 PM
hodge5's Avatar
hodge5
There is absolutely no reason that you can't leave the hubs locked in at highway speeds, mechanically. There is increased drag, and turning means wearing, but that's it. There are plenty of 4WD's on the road that has the fronta axle turning all the time- late model Rangers, Jeeps, Chevrolets, Dodge trucks, Toyota Landcruisers, etc.
Driving with your hubs locked in is the same as the rear axle turning. The only no-no is engaging the transfercase on dry, hard surface.
You will (most likely) do damage if your rear tires are spinning, you've engaged 4WD, and the auto hub delays and suddenly engages. Locked hubs is the better alternative.
Old Feb 17, 2015 | 11:11 PM
ashleyroachclip's Avatar
ashleyroachclip
I use the manual locking feature of the auto hubs , lock them and forget them .
Absolutely no ill effects..
My old ranger, 94 , I converted.the hubs first thing.
Then swapped out the electric transfer case crap, for a manual.
I don't think I ever unlocked those hubs much in 10 years , and 568,000 miles.
I rebuilt the front end , all new u joints, ball joints etc,,,at 300.000 miles.
Never had anything go wrong.
Old Feb 18, 2015 | 07:56 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
I got sick of my factory hubs, so went to Warn. I don't have any problems leaving them locked... and it's honestly not that big of a deal to get out and lock em in. I do it in the garage before I leave if I think I'll need 4x4 that day.
https://www.ford-trucks.com/forums/1...onversion.html
Old Feb 18, 2015 | 11:08 AM
CollinsCD's Avatar
CollinsCD
I wish I could get my truck in my garage. I have a standard door height opening and I need to remove my antenna in order to fit through the door. My older Ford trucks was much easier to remove the antenna.
Pgh Rebel
2009 - 2014 F150
Dec 14, 2017 06:20 PM
cattlerancher
Nov 27, 2014 08:43 PM
jts140
Jan 1, 2013 11:49 AM
Audball
Dec 29, 2008 07:12 PM
Pinky Demon
Sep 30, 2008 08:34 PM
