Fan hub lube
Old Feb 16, 2015 | 08:38 PM
Tomc750's Avatar
Tomc750
Fan hub lube
I am working with a 8RT engine that I have installed in my 8N Ford tractor. The fan hub has no oil, at least that will drain out with the plug removed. However, the bearing is smooth and tight. I can find no information in any manual regarding amount or viscosity. can anyone help?
Old Feb 16, 2015 | 09:14 PM
harleymsn's Avatar
harleymsn
The original owners manual called for 30wt oil, but Ford revised that to a gear oil, 90wt I think (I'm working during a power outage and can't look it up tonight) anyhow, it only takes 2 oz. the proper way is to remove the screw, add the 2 oz, turn the screw to the bottom, and went it stops pouring out, it is at the 2 oz level, then replace the screw.. The screw hole is actually a shaft that extends into the hub and acts as the measuring agent.
Old Feb 17, 2015 | 11:31 AM
Tomc750's Avatar
Tomc750
Sounds like a heck of a good answer, just what I was looking for! Don't know why I could not find it in my manuals. I am now located in NY but moving to TN, near Greeneville, maybe our paths will cross. Thank you!
Old Feb 17, 2015 | 02:00 PM
harleymsn's Avatar
harleymsn
I've traveled your area a lot, lived in WNY for 54 years before moving here 10 years ago. When you move to Greenville, it put roughly about the same distance away then.
Here is a link to give you a bit more info and history on the fan hub Ford Oil Filled Fan Assy
Old Feb 18, 2015 | 09:55 AM
Tomc750's Avatar
Tomc750
Joe, thanks much for all the info on the fan hub. Certainly removes all doubt on how to maintain it.
D Sokol
Apr 12, 2016 07:51 AM
randycarmichael
Nov 11, 2015 12:01 PM
travelingman55
Feb 21, 2013 10:49 PM
pkcatfish
Jan 22, 2006 09:28 AM
chicowoodhill
May 11, 2005 01:38 PM
