64 front hubs
Old Feb 16, 2015 | 09:27 PM
robbyriot's Avatar
robbyriot
I'll do some looking and see if I can find it. Out
anthony myrick's Avatar
anthony myrick
mine will be coming off soon the replace brake lines but It may be a couple of weeks
Old Feb 16, 2015 | 09:59 PM
resonateur's Avatar
resonateur
Robby:
I'll hang on until you find out for sure if you need the hubs or not. They're separated and cleaned up, but not a problem if you don't need them.
Old Feb 16, 2015 | 11:18 PM
robbyriot's Avatar
robbyriot
Thanks I'll let you know as soon as I find out.
Old Feb 17, 2015 | 09:58 PM
Jim Beckers's Avatar
Jim Beckers
I installed the Speedway disc conversion on my '64 F100 and am very pleased with the kit and the results. I would say go for it if you find out that the F250 spindles are the same. You would of course need to run 5X5.5" rims on the front.
Old Feb 17, 2015 | 10:09 PM
robbyriot's Avatar
robbyriot
Thanks. Was it pretty easy to install? Not a issue about rims I wanna get some new ones anyways.
Old Feb 17, 2015 | 10:18 PM
Jim Beckers
Fairly straight forward on the install. Directions leave a little to be desired, but it all comes together fine. Just some minor grinding on the calipers for clearance (common issue).
Old Feb 17, 2015 | 10:23 PM
robbyriot's Avatar
robbyriot
That's what I've heard. Just wanted to make sure there wasn't any crazy welding or anything.
gohunt
Mar 11, 2017 09:57 AM
Mr. 64
Mar 31, 2014 11:37 PM
twinbeam66
Jan 20, 2006 09:08 PM
saanders
1978 - 1996 Big Bronco
Feb 16, 2003 06:08 PM
