Sponsored by: Auxito
Coolant condition?
Old Feb 16, 2015 | 10:46 AM
usafstud's Avatar
usafstud
Coolant condition?
97 4.6 f150 with 174k miles
Why is it so brown after so many flushes?
I flushed it 30 months ago with preston coolant and distilled water.
Old Feb 16, 2015 | 08:10 PM
pdqford's Avatar
pdqford
When you did the flush 30 months ago did you also open the block drains?
Old Feb 16, 2015 | 08:39 PM
steve(ill)'s Avatar
steve(ill)
to do a proper flush you need to buy a plastic TEE and install in one heater hose. You connect a garden hose to the TEE and flush thru the motor with the drain valve on the radiator open, and the fill cap off the overflow tank. You put about 10 GPM thru the system for 10 minutes and it will run clean. I try to pinch one heater hose, then the other, to force the water thru the heater core, then thru the block, etc
Old Feb 16, 2015 | 09:40 PM
usafstud's Avatar
usafstud
No I did not. Picture of the block drain? Location?
Old Feb 16, 2015 | 09:45 PM
Ancona's Avatar
Ancona
Personally, on an engine that old and with that many miles, I would not attempt to remove the block drains. Very good chance they are rusted-in-place and will be difficult to remove. The better method is to buy a flush kit like steve mentioned.
Old Feb 17, 2015 | 02:45 PM
pdqford's Avatar
pdqford
Easiest one to get to is on the driver's side of the block near the bell housing. After removing the drain plug you will have to use a screw driver or punch to break the crust of junk in there to get the coolant to flow out of the block drain.
Flush it as Steve described, but with the block drain plug out. When it runs clear, close all the drains, fill it with water and run the engine for about 10 minutes. Then (don't burn yourself) open all the drains and flush as Steve described. Keep repeating until it runs clean after running the engine.
Hint - it took NINE cycles before my '02 Navigator ran clean. The problem is the drain for the radiator is slightly above the lower radiator tank and the passenger side block drain above the starter is too difficult to access.
I take the plastic coolant tank out and put about a cup of small, sharp, fine stones in it with hot water and detergent and shake the heck out of it to clean the inside. Then flush it out. Be sure to get ALL the stones out of the coolant tank! This is not a winter type job!
Old Feb 17, 2015 | 09:02 PM
iamvandemon's Avatar
iamvandemon
This is one of the most complete collections of information about coolant systems and problems.
Don't Rush the Flush
99ExpyProblems
Sep 1, 2018 07:45 AM
Waterlogged
Mar 14, 2016 08:25 AM
Macs1964F100
Jun 4, 2014 09:29 PM
jason86
1997 - 2003 F150
Oct 16, 2007 05:02 PM
CheaperJeeper
Apr 25, 2007 12:07 AM
