What is a good Performance ignition system?
Old Jul 22, 2003 | 09:27 PM
Custom 1975's Avatar
Custom 1975
Once I get my engine problems straightened out (See my previous Posting), I plan to install a good performance ignition system.
I am interested in hearing what you all would recommend. I am Running a 1975 360 (Modified to 390 during overhaul). I want low end power, (I tow a 26' Travel trailer).
thanks
Custom 1975
Old Jul 22, 2003 | 09:45 PM
gtex's Avatar
gtex
MSD 6AL, MSD coil, and MSD 8.5mm wires with the MSD billet Dizzy. That's the $500 version :-)
I think their name carries a good reputation, and my personal experience with their tech service was very good.
I'm sure you'll get some other reccomendations here shortly. they'll range from a rebuilt stock Duraspark up to the system I'm running and probably beyond :-)
good luck
Old Jul 25, 2003 | 07:18 AM
luvfordtrucks's Avatar
luvfordtrucks
i'd have to agree with anything msd, but then again it depends. msd makes a 5 a box i think. its the step below the 6a, and considerably cheaper. being that it too is a multiple spark box and the coil is where the power is im not sure what the big difference is between it and the 6a, but im sure it would be fine for medium performance or more........
you didnt mention if your using a points type or dura spark distributor or if you have an after market one. as long as its a non point distribitor it should work fine. for installing a trigger in a point type distributor you cant go wrong with a mallory unilite or pertronix ingniter trigger, although i may switch to the pertronix eventually as it uses the stock type rotor as where the unilite uses a special rotor thats harder to find if you need one fast.
Old Jul 25, 2003 | 07:27 AM
luvfordtrucks
by the way, i spaced the fact that you said you'd be towing a trailor, and you may want to look into an msd item thats optional with there stuff........its the inside the cab dial that allows you to advance and retard your timing manually with the twist of a **** which may come in handy when your towing........
Old Jul 26, 2003 | 04:09 AM
docholiday72tx's Avatar
docholiday72tx
I'm running the msd 6a box, msd blaster 2 coil, and a regular ford electronic distributor. I haven't had any problems, and it runs like a top.
Old Jul 26, 2003 | 09:37 AM
Custom 1975
I think i've decided on the MSD 6AL with MSD FE Billet Distributor(since I have to replace my distributor anyway)and Blaster Coil . Anything I should watch out for during installation?
Custom 1975
Old Jul 26, 2003 | 10:19 AM
gtex's Avatar
gtex
Nothing special to installing the MSD Dizzzy vs. the stock dizzy. Just take it slow coming out if possible. Hopefully your oil pump drive shaft retainer clip is still in place. I failed to resinstall mine, and twice I pulled the shaft out of the pump when trying to reinstall the dizzy. Then I had to lift the engine, drop the oil pan and reinstall the shaft, no fun.
Old Aug 20, 2003 | 11:32 AM
redneck hillbilly's Avatar
redneck hillbilly
The dizzy we are talking about is the MSD Ford FE Pro Billet Distributor right? I don't see a listing for a MSD Billet Distributor.
This distributor has no vacuum advance feature. I don't know if this is important to you but it is worth mentioning.
Old Aug 20, 2003 | 12:29 PM
gtex's Avatar
gtex
Correct, I'm talkin about the only distributor MSD makes for the FE and it does not have vacuum advance. A plus in my book.
Old Aug 23, 2003 | 10:40 PM
dinosaurfan's Avatar
dinosaurfan
Custom, your 75 has a duraspark on it now, right ? That is the dizzy you need. You can spend lots of $$ on other dizzys but you won't gain anything. I like to run a Ford Duraspark dizzy, with a Jacobs coil and a LX101 brain box ( Chrysler style) The setup has only 4 wires to hookup and works very well. And you NEED a vacuum advance, especially if you're going to tow. The guys who run without one are giving away lots of their fuel mileage. DF
Old Aug 24, 2003 | 10:03 AM
Custom 1975
Yes, My truck has a duraspark on it now. I do need to replace the Dizzy due to wear. I did check on an MSD FE Billet Dizzy and did find out that it did not have vacume advance.
Are you saying that for towing I should stick with a Duraspark Dizzy to keep the vacume advance?
Old Aug 24, 2003 | 10:53 AM
gtex's Avatar
gtex
DF is very knowledgeable about FEs, but I myself prefer the simplicity of the mechanicqal advance on the MSD Billet dizzy. There are several spring and stop bushing combinations that allow for a large variety of advance curves and max advance settings. I don't see what a vacuum advance would have to offer above and beyond the MSD. I also believe that an engines vacuum profile changes somewhat with different intakes, cams, heads, carbs etc. This would probably require some tuning on the vacuum advance, and I don't believe it's near as easy to tune as the MSD. 2 screws, a spring and/or a bushing then try it agin to see if you like it.
However, the MSD is a bit more expensive and mine did have a magnetic pickup failure after only 4000 miles. MSD replaced the pickup for free, even though I was just out of warranty.
My 2cents
Old Aug 24, 2003 | 11:07 AM
Custom 1975
Thanks for the 2 cents Gtex.
How is the best way to determine the advance curve you want to go with? Just through trial and error?
Old Aug 24, 2003 | 12:41 PM
gtex's Avatar
gtex
Using a tachometer and a timing light is the technical answer.
Trial and error using your ear and seat of the pants is the most common method :-)
The MSD manual goves a lot of info on the advance curves and max advance setting for each spring and stop bushing setting.
Old Aug 24, 2003 | 03:50 PM
dinosaurfan
Custom, yeah, you need the vacuum advance when towing. Actually, you need it for anything other than Drag racing only. The mechanical only advance is easier to setup, but doesn't give the engine what it neeeds. Your engine wants more or less advance depending on rpm and the load the engine is pulling. Without vacuum advance, the dizzy has no way to advance or retard the timing as engine load varys. Spend 10$ and put new bushings in your duraspark dizzy, or spend about 40-45$ and get a rebuilt duraspark. The MSD is more money for less power and economy. Why would you want that ? DF
