Rust repair
Old Feb 15, 2015 | 08:53 PM
bpimm's Avatar
bpimm
Rust repair
When I bought my 83 I knew it had a couple rust issues, you could see the rust coming through the driver side cab corner and on the driver side door sill. I thought someday I'll have to fix that... The truck was in the shop for a heater core and I have suffered from a massive case of project creep, I'll cover the other parts of the creep in another installment but needless to say I ended up taking care of the rust.
Part of the creep was heated mirrors so the kick panel came off to get a wire into the door and this is what I found.
Front of door opening
Back of door opening where I saw the rust on the sill
I stuck a screwdriver through it with no effort.
After cutting the cancer out
That's a piece of square tube clamped underneath to help lign up the new sill edge. And the front.
Here is the first piece to go back in. an angle to rebuild the inner side of the door sill.
Here it is mostly welded in.
Another piece and the sill is back together.
and after grinding
Seat belt mount moved to the new sill
I cut this piece out to get clearance to sand blast in behind it so back in it goes.
First piece of the floor to back in
After some hammer and dolly and grinding.
Rebuilt the bottom of the door opening at the back of the door.
Then the side piece to finish off the door opening.
and welded in and ground.
First piece of the front floor the small vertical piece.
Then the channel floor.
the floor patch
The outboard side of the channel
I decided not to wait until I could get a cab corner so I fab'ed one up, I couldn't get to the back of the cab because I'm not sure if the bed can be removed form this truck because the lift gate is welded to the frame so that area may have to be dealt with later.
rough shape
fitted and held on with magnets
Welded in and ground
and now for the fill piece.
Template and rough cut part.
Here is how I bend the parts, I have a break for the longer bends.
coated in weld through primer and ready to go in.
I forgot to take pictures of this part going in but here it is in place.
Back
Front.
With door closed.
A little bondo and primer and it will be ready for paint.
Old Feb 15, 2015 | 09:10 PM
Franklin2's Avatar
Franklin2
You do good work. That took a lot of time fabbing it up though. They make a rocker panel piece that works very well for a repair just like this(the more expensive one). You would have needed the outer floor repair piece and the rocker piece. They spot weld together to form the ridge you called the "channel". If you look close at the other side, you will see the raised part that the rubber slips over is really two pieces spot welded together.
Now that you have all this fixed, look at the seam that goes from the gutter over top the door to the rear top corner of the cab. The factory putty likes to dry out and water gets in. It runs down the inside of the cab where you can't see it and rusts out the rear cab corners.
Sheetmetal work is it's own trade, and it looks like you have the tools and the knowledge to make what you need.
Old Feb 15, 2015 | 09:41 PM
bpimm's Avatar
bpimm
Thank you, I looked at the repair panels and decided it would be cheaper to spend the time fabing what I needed, My time is cheap to me..., there is a fair amount of work to get the whole sill out to install the replacement, the sheet metal was already on the shelf.
I actually put it back together the same way the factory did, on this truck the channel is formed by the vertical edge of the floor and a angle spot welded down to the top of the sill. The floor and sill do form a pinch weld where they join but it goes down and forms one side of the sill channel.
Kinda hard to see there but the floor is toward the bottom of the pic and the angle starts about 1/4" away from it going up in the pic.
I'll check that out, I also noticed water trails from the back window so I need to get that out and sealed up as well. It could be fun with the bed not coming off and having toolboxes mounted to the top of the sides, Might have to take the boxes off to get to the window.
That it is, I like playing with it but I don't think I would want to do it for a living, I also like tools and seem to collect them.
Old Feb 25, 2015 | 10:06 AM
bpimm's Avatar
bpimm
Franklin, I'm assuming this is what you were talking about?
I'll seal that up before the truck leaves the shop.
Old Feb 25, 2015 | 10:14 AM
Franklin2's Avatar
Franklin2
Yes. That's usually what rusts out the rear cab corners.
Old Feb 25, 2015 | 10:25 AM
trevisM's Avatar
trevisM
Great job and pictorial!
Old Feb 25, 2015 | 05:31 PM
maytag906's Avatar
maytag906
Looks good, nice job!
Old Feb 26, 2015 | 04:58 PM
Old Hickory's Avatar
Old Hickory
A very great job. Thanks for sharing it with us.
Old Feb 27, 2015 | 12:11 PM
bpimm's Avatar
bpimm
Thanks Guys and you're welcome.
Old Feb 27, 2015 | 02:24 PM
JordanL91's Avatar
JordanL91
You are a body repair / welding God! I am not worthy!
Old Feb 28, 2015 | 10:49 AM
Diesel_Brad's Avatar
Diesel_Brad
Very nice job making all those pieces. I would certainly not have the patients to make all them when you can buy them for under $100
Old Feb 28, 2015 | 12:49 PM
bpimm's Avatar
bpimm
But where's the fun in that?
besides it would have taken a week to get the parts and I had it done in 2 days.
Old Feb 28, 2015 | 01:00 PM
Diesel_Brad
Bronco graveyard has stuff to me in 1-2 days. My time is better spent elsewhere then making already made parts.
But you did a nice job. Better than 99% of the rust repair threads I have seen
1985 Bronco
1978 - 1996 Big Bronco
82
Oct 23, 2018 08:04 PM
Brad sxt
Jan 6, 2017 01:54 PM
'51 Ford
16
Jun 21, 2012 08:48 PM
hobbystock98
Paint & Bodywork
13
Jul 1, 2011 06:36 PM
pbStriker38
51
Jun 27, 2009 08:27 AM
