intake manifold pan/interchangeability?
Old Feb 15, 2015 | 06:23 PM
benbuilder's Avatar
benbuilder
I just purchased a 2 barrel 302 intake Casting number D7OE AC. I want to put it on my 77 302 flairside in place of the 4 barrel Edelbrock currently on the truck. I have two questions.
I think I know the answer to the first. From the casting numbers I can assume this manifold came off a Fairlane or Torino . It will fit on my 302, right?
The second question I have is regarding a "pan" on the underside of the intake. It appears to be held in by two pins. I have researched to see if this is replaceable but have not found anything. Mine has a small slit I noticed after power washing it. Can it be welded? Is there a replacement available?
Thank You
Old Feb 15, 2015 | 07:06 PM
HIO Silver's Avatar
HIO Silver
If it's steel it can simply be welded like a body panel.
Here's a very low buck way to dissolve the rust on that splash shield: Electrolysis - Rust Removal
.. or bring it to a machine shop and have it media blasted and stitched up. Prolly less than buying a new one. If you were local I'd do it for nothing.
Old Feb 15, 2015 | 09:13 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The manifold will fit.
As for the "pan", that's a heat shield to keep oil from splashing on the hot exhaust crossover section of the manifold and cooking, then turning into carbon. The two "pins" are rivets. Not a 100% sure but that slit may be factory. The shield isn't liquid tight, that may be a drain hole for oil that has splashed up underneath the manifold to drain back into the lifter valley. Personally I wouldn't worry about it.
Old Feb 15, 2015 | 09:23 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Here's another small block intake, it has the same slit.
Old Feb 15, 2015 | 09:33 PM
HIO Silver's Avatar
HIO Silver
Yup...that's a drain. The OP's is a lil crushed it would appear.
Old Feb 16, 2015 | 01:47 AM
benbuilder's Avatar
benbuilder
Thanks for the help guys.
JRB64
Sep 3, 2017 12:11 PM
kr98664
May 14, 2017 09:08 PM
tbruz
May 19, 2016 07:57 PM
guywhalen00
Jul 5, 2007 07:18 AM
78F1504X4
Sep 3, 2004 10:49 AM
