1978 - 1996 Big Bronco
84 bronco II help!!!
Old Jul 22, 2003 | 07:05 PM
cezarleo03's Avatar
cezarleo03
Question 84 bronco II help!!!
I recently purchased an 84 bronco II w/ a 2.8 engine and am having a couple of problems. The temperature dummy light comes on after the engine has been running for a few minutes. I replaced the radiator, head gasket, machined the heads, water pump, and finally the thermostat, and the light still comes on. One side of the radiator (left) gets hot, and the other stays cold. The upper left radiator hose stays hot while the lower right hose goin to the thermostat does not. The thermostat is positioned so that the thermometer is facing the hose and radiator like I have done on all other cars&trucks. Am I putting the thermostat in wrong on this engine??????? I also have a fuel problem. The engine will run and suck fuel from an external gas tank, but not from the gas tank. Replaced fuel pump and attempted to blow out fuel lines. Any ideas??????? PLEASE HELP!
Old Jul 23, 2003 | 05:16 AM
Sudsrat's Avatar
Sudsrat
There is a forum for your ride.Look for BroncoII,under
"SMALL" chassis trucks. Good luck.
Berardini2121
Apr 22, 2016 11:49 PM
KLWillis
1983 - 2012 Ranger & B-Series
Mar 28, 2011 02:06 PM
Celtic Nomad
15
Sep 1, 2009 06:11 PM
rrumba
28
Jan 27, 2009 08:28 PM
HangGlider
Jun 7, 2007 07:49 AM
