Sponsored by: Real Truck
DPF delete and tuner
Old Feb 13, 2015 | 05:56 PM
batfire2000's Avatar
batfire2000
Help !! So much information I'm confused. All I want to do is delete the dpf with a straight pipe and tuner. These kits are around 700. Will that work ? They mention that the tuner deletes the egr also so it can be blocked or eliminated. How would I block it. I would like to do all this myself.
Old Feb 13, 2015 | 06:01 PM
batfire2000
Egr
Do you have to block the egr ?
Old Feb 13, 2015 | 08:03 PM
dualwheels66's Avatar
dualwheels66
You can delete with just a delete pipe, a pipe that replaces that whole 3 foot long unit or a full delete which deletes everything from the flange all the way back to the bumper. You can opt for a kit with or without muffler. You will also need a tuner that is capable of turning off the DPF system. You do not have to block off the EGR but you can turn it off with the tuner, however it is best to remove the EGR. There are block off kits available. Come over to powerstrokearmy and read more.
Old Feb 13, 2015 | 08:48 PM
2ndStroke's Avatar
2ndStroke
6.4 or a 6.7?
Gorby
6.7L Power Stroke Diesel
15
Mar 2, 2025 11:00 AM
ngng
52
Jan 30, 2025 11:09 AM
Bohen
98
Aug 30, 2019 10:20 PM
Superdave831
Feb 19, 2018 09:49 PM
TREELIZARD
17
Jan 22, 2014 05:42 AM
