Sponsored by: Real Truck
Trailer Brake Contoller Issues
Old Feb 11, 2015 | 08:28 PM
motomax55's Avatar
motomax55
Hello All,
I need to tow an equipment trailer that has a 6-round pin connector. I picked up the converter to go from my 7pin to the 6 pin. It fits perfectly.
I tried testing the lights and stuff and everything looks great. The only problem is I can't get the brake controller to recognize the trailer. I push the manual slider to activate it, but it keeps saying "Trailer Disconnected" is there something obvious that I am doing wrong?
I imagine if I had it in upside down, none of the lights would have worked on the trailer.
Any other input?
Thanks so much
Old Feb 12, 2015 | 05:22 AM
redford's Avatar
redford
FTE Leadership Emeritus
What type of brakes does the trailer have?
Old Feb 12, 2015 | 07:06 AM
DPorter's Avatar
DPorter
There are two wiring patterns. The brake wire is in different locations. Do you have the correct one?
Old Feb 12, 2015 | 03:39 PM
motomax55's Avatar
motomax55
Honestly I'm not sure. Do you know by chance where I could find the wiring diagram?
Thanks!
Old Feb 12, 2015 | 03:41 PM
motomax55's Avatar
motomax55
I believe they are just electric actuated drum brakes, not electric over hydraulic.
Old Feb 12, 2015 | 03:43 PM
DPorter's Avatar
DPorter
Not at the moment. Google 7 pin wiring pattern.
Old Feb 12, 2015 | 05:46 PM
redford's Avatar
redford
Some 6 in connector are wired like this:
Note the brake is in the center and 12V charge is pin S.
Some, like this:
Note the brake is now on what was the "S" pin and the 12V CHARGE is in the center.
Old Feb 12, 2015 | 07:13 PM
ligito's Avatar
ligito
"S" pin? I see B, on the 6 pole and 2, on the 7 pole.
The "S", on the top diagram is the same position as the "B", isn't it?
Old Feb 13, 2015 | 05:09 AM
redford's Avatar
redford
One system calls it "S" and the other calls it "B".
Alan G
6.7L Power Stroke Diesel
Jun 19, 2018 08:50 AM
seventyseven250
All Things Towing
13
May 22, 2017 09:24 PM
contento
All Things Towing
Jun 7, 2014 07:16 AM
MKRemi
22
Apr 12, 2012 07:48 PM
dixoncity
23
Aug 30, 2011 09:22 PM
