Low idle speeds. Please help!!!
Old 03-15-2012, 02:45 PM
LCGRZY's Avatar
LCGRZY
LCGRZY is offline
I have been having some issues with my 1998 Ranger XLT 4x4 Off-Road 4.0 EFI. For a while now it has been idling low, especially when I try to start it when it is warm. My mechanic suggested cleaning the throttle body with carb cleaner. He did it once and it seemed to work for a little while, but then it got worse. I tried cleaning it myself and now it will hardly run, unless it is moving. Also there is a good chance that the little red straw that came with the carb cleaner is somewhere in my throttle body or combustion chamber.
Right now when I start it the rpms start normal for a second then dip to almost nothing, then jump up, then dip etc. Only now the engine will cut if I am stopped and I don't apply a little gas. What should I do, the local shop can't look at it until Tuesday and I use my truck every day.
BTW the truck runs fine when I am cruising above 40 mph. When I let off the gas the rpms drop.
I know that it is not the battery, I had it checked.
Please advise.
Old 03-15-2012, 03:36 PM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
Check the IAC - idle air control
With the truck being that old, it might need cleaning
Or replacing.
Old 03-15-2012, 03:44 PM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
Look for the straw!
And read thru this thread.
https://www.ford-trucks.com/forums/1...rol-valve.html
Old 03-15-2012, 07:24 PM
LCGRZY's Avatar
LCGRZY
LCGRZY is offline
I looked and looked and looked for the star in the throttle body, in the engine compartment, and in the ground underneath. What are the odds and consequences if the straw ends up in a cylinder?
Tried cleaning the iac (that's how I lost the straw), going to get a replacement asap.
I will keep you posted. Let Let me know about the straw.
Old 03-15-2012, 10:11 PM
michigan66's Avatar
michigan66
michigan66 is offline
Be sure you use a plastic safe cleaner, not carb cleaner. Both your truck and your wallet will thank you. The carb cleaner will remove the coating in the air intake system, allowing it to get gummed up fairy quickly.
Old 03-16-2012, 07:05 AM
LCGRZY's Avatar
LCGRZY
LCGRZY is offline
New IAC valve did the trick. Idles like a champ now. Thanks guys. I am still concerned about the straw. What wipl happen if the straw is in there?
Old 03-16-2012, 07:18 AM
Gabel1234's Avatar
Gabel1234
Gabel1234 is offline
Interesting thread. I'm learning lots!
timcohomerepair
07-22-2008 06:54 AM
Skyline Drive
12-29-2003 06:52 AM
zoti
11-11-2003 06:54 PM
Dayrun
Modular V8 (4.6L, 5.4L)
01-29-2003 03:11 PM
88iline6
07-21-2001 11:48 AM
Quick Reply: Low idle speeds. Please help!!!
