High idle issue, need help please
Old Jul 19, 2008 | 07:16 AM
timcohomerepair's Avatar
timcohomerepair
My 2000 Ranger (manual, 3.0) has an idle that sticks at between 2-3000 rpm depending on how far depressed the gas pedal was when driving, and revs up even further before slowly dropping to 1200. It does this sporadically when at operating temp. I changed the IAC and it was great all that day, and now doing it again. Would MAF or TPS be next? Is there a way to diagnose? I have heard of a high idle repair kit, is this for my truck? No check engine light, just high idle....
Thank you, Tim
SLC, UT
Old Jul 19, 2008 | 01:59 PM
scrapyardking's Avatar
scrapyardking
First thing I would check for is any vaccume leaks around the throttle body. Thats what caused mine to do the same thing.
Old Jul 19, 2008 | 03:34 PM
Pablo-UA's Avatar
Pablo-UA
and try to clean IAC... use tb cleaner. I used TB cleaner and carb cleaner.....
Old Jul 20, 2008 | 09:04 AM
timcohomerepair
Thank you both. Can I spray carb cleaner around the throttle body to check for vac leaks? Or water? What is the best way to check for this? Because the rpm it sticks at depends on how far the pedal was depressed, I was thinking throttle position sensor....no?
Tim
Old Jul 20, 2008 | 10:05 AM
Pablo-UA's Avatar
Pablo-UA
yes, you can.
but you can unscrew IAC, close its holes with fingers and ask someone to start engine. If idle is slower, may be IAC valve got stucked. So remove IAC solenoid and clean it inside
Old Jul 20, 2008 | 01:17 PM
timcohomerepair
I replaced the IAC 3 days ago with a new one. I will inspect it, but am reluctant to clean out a new part. That is why I was trying to move on to other possibilities.
Thanks for any input or advise,
Tim
Old Jul 20, 2008 | 02:10 PM
timcohomerepair
update...I sprayed good carb cleaner all around the throttle body and around the intake manifold (not every square inch was accessble on the intake manifold) and the idle did not jump or flail. I then cleaned off the throttle butterfly face and it runs better. Can the throttle posisition sensor be cleaned?
Tim
Old Jul 20, 2008 | 03:25 PM
Pablo-UA's Avatar
Pablo-UA
no. there is a screw on throutle lever. try to disconnect IAC when engine is how and turning this screw get idle speed a bit slower then normal. Then connect IAC and let PCM ajust idle speed. Be sure throutle sppring is OK and cabel ajusted well and does not stuck.
Old Jul 20, 2008 | 09:23 PM
97ranger xlt's Avatar
97ranger xlt
make sure the pcv valve is good also...
Old Jul 20, 2008 | 09:28 PM
timcohomerepair
Would that cause high idle? Can it be cleaned or should I just replace? Where is it?
Thanks for the help, guys....
Tim
Old Jul 21, 2008 | 02:25 AM
Pablo-UA's Avatar
Pablo-UA
if PCV ore PCV hose sucks air you'll get fast idle. try to close hose.
Old Jul 21, 2008 | 09:27 AM
Bear River's Avatar
Bear River
Former ******
Since cleaning the TB helped, I would pursue that more fully. Remove the entire TB and clean it.
Old Jul 22, 2008 | 06:54 AM
97ranger xlt
Tim
yes it will cause high idle.
should be on the block underneath the intake manifold..
you can try to clean it but they're cheap anyhow.
