Did you use any fuel additive on any kind of regular basis?
Thanks
I used it religiously on the first set of injectors. On the newer set, I either use some or get fuel that has at least B5 in it. B5 is pretty common around here so the added lubricity in that means I can skip the additive.
Originally Posted by BadDogKuzz
Chris what tune of Tony's do you find you use the most for city/ highway (daily driving)?
Mostly a tow tune because I forget to switch it back, but economy or if I want a little more pep the daily driver tune.
And when you replaced injectors did you do new or reman?
If reman who did them?
AD's or did you do AC's or variation of what injector?
Because if you have 200k on reman's I am impressed.
I went with new injectors. All AD.
Originally Posted by guitarpicr
Do you tow regular with her?
Not as much as I used to, but still pretty regular. I've got the 25' gooseneck on the back of it right now from today.
Originally Posted by skipb88
wow...very nice. got me beat! I got a 6.4L that has 40,000 on it and on the 3rd engine!!!! (some of that may have been self inflicted) lol
Well done Chris! They don't get there on their own.
Not a lot of repairs given the miles. The things you'd expect just not many of them. IIRC you had more trouble with shocks than anything else. Still like the nifty backup light install.
Agreed on the leather. If you're in the saddle for a few hours, or just hot and sweaty after work, I want something that breathes!
I've taken to running Valvoline Premium Blue in the winter time because the engine just sounds better when cold running that stuff. Maybe the lower viscosity is why it sounds better when cold. Poor mans synthetic I guess.
Congrats on the milestone Chris! All your maintenance practices/procedures have got to be 100% on the mark. Not only is your most current oil analysis impressive - they all look great.
You have been on FTE pretty much since the beginning (I like to call you guys "First Ones") and your knowledge & expertise has helped me and countless others. Congrats again & I look forward to the million mile oil analysis!
