Sponsored by: Real Truck
ford brake controller
Old Feb 11, 2015 | 04:22 PM
jozan's Avatar
jozan
2005 f250 SD, has no upfitter switches or brake controller, got one at a JY found all the info on install and wiring for switches but a little unclear on the brake controller, is it plug and play?
Old Feb 11, 2015 | 04:27 PM
Poncho450's Avatar
Poncho450
I bought a Ford factory trailer brake controller for a 2013 F150. Pretty much plug & play, but a dealer has to reflash the truck's computer. I see your truck is older, but I would check into it.
Old Feb 11, 2015 | 06:02 PM
redford's Avatar
redford
FTE Leadership Emeritus
It is not plug-n-play on a 2005 SD. You also need to replace the master cylinder and get the truck programmed for the factory TBC.
Old Feb 11, 2015 | 06:03 PM
senix's Avatar
senix
plug/flash and you may need to change your master cylinder. Needed to accommodate an additional sensor I believe.
Old Feb 11, 2015 | 06:04 PM
moymurfs's Avatar
moymurfs
There are 2 different master cylinders used. One for the controller module and one without. SO, although the wiring pigtails are there, it wont work without the correct master cylinder. An aftermarket electronic module will work.
Old Feb 11, 2015 | 06:08 PM
senix's Avatar
senix
The ford controller is well worth the money in its operation if you decide to invest in it.
Old Feb 12, 2015 | 07:53 AM
Poncho450's Avatar
Poncho450
I thought so, which is why I did it with the last F150 I owned. They function great and they're made to be there in the dash. Much nicer appearance than most aftermarkets I've seen.
Old Feb 12, 2015 | 04:12 PM
Gage2502's Avatar
Gage2502
I don't know why I didn't order my truck with one...now its going to cost me.
...Gage
Old Feb 12, 2015 | 07:59 PM
Poncho450's Avatar
Poncho450
...Gage
I found online Ford places that were much cheaper than the closest Ford store for the part. Should be able to pop it in yourself and just have them do the reflash. Unless of course you have the master cylinder issue mentioned in previous posts.
Old Feb 12, 2015 | 08:19 PM
jozan's Avatar
jozan
Thanks for the info, wil get a MC, and have it flashed
Old Feb 13, 2015 | 12:57 PM
05F250DSL's Avatar
05F250DSL
I can't for the life of me figure out why the brake controller is not standard on these trucks. Its a SD not a focus. People buys these trucks to use. Then they only would have to make one master cyl. You think it would save them money and time on the line.
Old Feb 13, 2015 | 02:29 PM
Gage2502's Avatar
Gage2502
Ya I would have to get a new master cylinder....
Gage
Old Feb 13, 2015 | 07:48 PM
ALMACK's Avatar
ALMACK
^^ I agree.
The cost for the tb controller on the option sheet is reasonable, and as posted, it means Ford could get by with only using one master cylinder.
Court1317
Jun 10, 2019 09:33 PM
sailorman3
Apr 17, 2013 10:49 AM
RBALAN
Mar 23, 2013 07:30 PM
guthrie&co
Jan 21, 2010 08:25 AM
gregghealy
Sep 27, 2007 05:06 PM
