INJECTOR SHIMMING
Old Feb 11, 2015 | 11:20 AM
timmyboy76's Avatar
timmyboy76
INJECTOR SHIMMING
Seems legit to me, with these conclusions...(apologize to admin, if posting other site is wrong, but thought this idea/maintenance was worth noting)
7.3 injector shims | eBay
WOW - Diesel Forum - TheDieselStop.com
Old Feb 11, 2015 | 02:02 PM
Tugly's Avatar
Tugly
Without really mulling this over, it sounds like a legit stop-gap. It may very well extend the life of injectors with just this one problem. It's a gamble, but it's a cheap and easy gamble.
Old Feb 11, 2015 | 02:40 PM
SaintITC's Avatar
SaintITC
As my injectors are still sitting in a box, it might be interesting to see just what the clearance is on my injectors. How difficult are those solenoid retaining screws to remove? And are they reusable? But they seemed to work fine before, and we all know, if it ain't broke...
Old Feb 11, 2015 | 04:34 PM
Shake-N-Bake's Avatar
Shake-N-Bake
This appears to only address the one problem of not having enough head room for the armature plate to actuate the poppet valve. Which is usually due to a loose armature plate screw so that simply can be tightened. The more common problem is low deck clearance under the armature plate and that can only be solved with machining some material away.
In either case....it's best to balance the hold pressure for the high pressure oil anyway so one needs a bench test setup for that process.
Seems like a lot of effort for little reward to me.
Old Feb 11, 2015 | 06:02 PM
Tim at pis's Avatar
Tim at pis
^^^this makes no sense.
You will almost never find a loose armature screw. After several thousand injectors only a handful ever found loose. And I can't prove someone wasn't jacking around with those.
But why not try it. Some of your popular injector builders use them.
Old Feb 11, 2015 | 06:19 PM
Shake-N-Bake
A loose armature screw happened to me once....and to at least one other forum member that I can think of. I think it's more common then most people realize since the units usually get replaced anyway.
I am not saying that shims are a bad idea....just only solves the one problem....which one has to measure to see if there even is a problem.
I don't recommend folks rush out and start buying shim kits thinking it's going to make their truck run much better. If your injectors are that worn then the solution is a bit more intensive then a simple shim (IMO...)
I am not an expert on injector building but I have rebuilt a set myself and it's not something that I'd recommend to the average DIYer.
Old Feb 11, 2015 | 08:32 PM
whitetmw's Avatar
whitetmw
Right at about 4,000 is where you want to be.
3000gtman
Feb 2, 2017 08:27 AM
fordguy390
Dec 2, 2016 06:49 AM
wolffee
Mar 1, 2016 07:27 AM
onelessissue
Oct 25, 2014 12:07 AM
train460
Jul 20, 2004 08:40 PM
