after market bumper
Old Feb 10, 2015 | 09:05 PM
dentsides's Avatar
dentsides
after market bumper
I am looking for a tougher bumper for the 78 f150. I want to put a winch on it. I also live where wildlife frequently stops in the road and commit suicide.
I checked Ranch hand site. They don't make bumpers for our dentsides. Does any company make those type of bumpers?
Old Feb 10, 2015 | 09:21 PM
HIO Silver's Avatar
HIO Silver
JBG (Jeff's Bronco Graveyard) is the only popular retailer that I know of that carries Dentside winch bumpers. Otherwise, find one you like and contract a fab shop to adapt it to your rig.
Alternatively, order a winch plate and fairlead and start fabricating one to suit your taste and style. Order the winch later or at the same time... the minimum rating is twice the weight of your truck. Therefore 10,000 lbs but 12,000 lbs is better.
Old Feb 10, 2015 | 09:28 PM
dentsides's Avatar
dentsides
Thanks for the reply I will look at Bronco Graveyard. I will talk to a welder for a quote on making 1 fit.
I will go the route that fits my budget the best.
Old Feb 10, 2015 | 09:45 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Ranch Hand never made one for our year....best deal would be to find a Craigslist used one and get to modifying it.
Or..... Proto Fab Products Page #708 is nice!
Maybe you can get a fab shop to make one of there hard to find gems?
Old Feb 10, 2015 | 09:53 PM
77&79F250's Avatar
77&79F250
More ideas.....
Old Feb 10, 2015 | 10:09 PM
77&79F250's Avatar
77&79F250
The point of a receiver hitch in the front bumper is to be able to use the winch mounted plate as an option on the front or rear if needed.
QD (quick disconnect leading wire type) elec connectors for front or rear power, and you can use it on a trailer too....
I have a long set with QD's on one that fit the winch leads and the other ends are jumper cable clamps, I can use it with any truck....or any buddies truck.
I made it where you have to double pin the receiver in place. Sorry last pic is not so good. And that is NOT a Harbor Freight winch mount plate, that things is a beast!
dentsides's Avatar
dentsides
Thanks. I like that 1 on the bronco.
Old Feb 10, 2015 | 10:12 PM
dentsides's Avatar
dentsides
I have looked into front reciever hitches and can't find them for a 78. I was thinking of welding one into a bumper, when I get a new one.
Old Feb 10, 2015 | 10:18 PM
77&79F250's Avatar
77&79F250
Remember what ever sticks above the bumper that is not attached correctly or built out of thin wall tube is going to destroy you nice outer grill shell/inserts and hood and maybe a radiator if you use the wrong material and or its a crap weld job.
I rate stuff at a 180 to 375lb bambi proof-ness. Use hardened bolts, lock nuts, grade 8 to 10. Double the mount plates, bolt it on each side of the frame and use spacers between the outer frame plates. Make sense?
Old Feb 10, 2015 | 10:23 PM
77&79F250's Avatar
77&79F250
Here is the bumper design. 2 heavy wall tubes going in side the frame (yes hollow) and then bolted and welded to the frame ends.
And some other ideas for you.
Old Feb 10, 2015 | 10:30 PM
77&79F250's Avatar
77&79F250
In between the frame rails, 2 receiver points is better, but more work, 2 handle a hard side pull better.
But limits the trucks that can use it, EVERY one atleast has a rear receiver.
Get a JY rear one for cheap and mod it to fit where the receiver part lines up with the front licence plate.
Old Feb 10, 2015 | 10:31 PM
dentsides's Avatar
dentsides
I didn't consider the double mounted plates thanks. I have seen too many cars and trucks around here turned to junk because of deer and the occasional elk out for a stroll...
Old Feb 10, 2015 | 10:34 PM
77&79F250's Avatar
77&79F250
Having a HD dumper is great unless it is mounted with cheap bolts and using the same "made to flex" frame ears.... well not so much then.
Old Feb 10, 2015 | 10:50 PM
dentsides's Avatar
dentsides
The truck has the same dented bumper and grill on from the previous owner. I don't want to replace the grill shroud and inserts until the bumper is traded out for a stronger one.
Old Feb 10, 2015 | 10:58 PM
dentsides's Avatar
dentsides
A mine truck, tall, backed into it recently the hitch went between my headlight and radiator. That is another reason I am thinking of some type of gaurd there.
Tim Young
Sep 4, 2011 11:01 AM
poffutt
1978 - 1996 Big Bronco
Jan 31, 2006 08:45 PM
ChrisAllen1090
Feb 20, 2003 09:26 AM
marriedguy1
Texas Chapter
Jan 7, 2003 03:27 AM
Kemicalburns
Oct 31, 2002 08:27 PM
